momentum source
Old   January 18, 2011, 11:44
Default momentum source
vinesh
vinnithepooh is on a distinguished road
dear all,
has anyone worked on giving momentum source in rhoPorousSimpleFoam?
could somebody give me a hint as how to proceed.
thanks in advance.
vinnithepooh is offline   Reply With Quote
Old   January 20, 2011, 05:01
Nakul
nakul is on a distinguished road
I haven't added a source term before but you may just define the "source" field in createfields.h file locate in the source code of this solver that you would find in "applications" folder.
Also you may add your source term to momentum equation in the C file located in the source code folder of this solver. Then you may specify relevant solvers to solve for this sorce term in fvSolution.
You may find the exact procedure if you thoroughly search this forum.
nakul is offline   Reply With Quote
Momentum source coefficient and convergence meh CFX 9 October 12, 2020 08:37
Mass source, Momentum source theory. diffo FLUENT 4 August 21, 2009 10:26
Problem with Mass source, Momentum source theory diffo Fluent UDF and Scheme Programming 0 August 20, 2009 06:10
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
