Error message when reconstructing registered object hs |
February 22, 2011, 04:40 |
José Rodrigues
Rep Power: 15 |
When I try to reconstruct a case that I ran in parallel I get the following message: Cannot find 'value' entry on patch Wall of field hs in file "/home/jose/CFD/OpenFOAM/jose-1.7.1/run/FLOXCOM/ModelA2SS/processor0/4.5/hs" which is required to set the values of the generic patch field. (Actual type gradientEnthalpy) Please add the 'value' entry to the write function of the user-defined boundary-condition or link the boundary-condition into libfoamUtil.so The field in question is hs which is written in the output using the functionObject writeRegisteredObject. In fact, the gradientEnthalpy patchField seams to replace the keyword 'value' by 'gradient'. I would replace it myself ony if I knew where the 'write function' for this BC is. Any idea? About the second suggestion of linking the BC into libfoamUtil.so, im not really sure what it means. I need to reconstruct the case in order to export to TecPlot. Any idea on how can I overcome this problem? THX Jose |
Problem of reconstructing pointVectorFields with parallel mesh motion (1.5.x) | LESlie | OpenFOAM | 0 | November 6, 2009 06:07 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
OpenFOAM141dev linking error on IBM AIX 52 | matthias | OpenFOAM Installation | 24 | April 28, 2008 15:49 |
Reconstructing Coefficient Matrix from lduAddressing Object | cliffoi | OpenFOAM Running, Solving & CFD | 0 | December 7, 2007 07:16 |
