Jo Bouchard
Rep Power: 0 ![]() |
i'm testing OpenFoam with the simple Restivo case. Can't get the Low-Reynolds LamBremhorst model to converge. Epsilon always gets infinite and nut to zero. Works ok with Launder-Sharma model. Also, Mesh is fine enough for a LRN model. Any advice? Experiences with the LamBremhorst model? Thanks |
Nikesh Bhattarai
Rep Power: 13 ![]() |
Hii Jo,
Any chance you managed to solve this problem?? I too am encountering this problem at the moment. Any help you could pass on?? I am implementing simpleFOAM to run a simple 2D flatplate case. I am stuck with assigning the boundary condition for epsilon at the wall. Would be really great if you can help!! Thnks Nikesh |
Jo Bouchard
Hi Nikesh,
The only way I could get the LRN LB model to converge is with a very dense mesh near the boundaries. This is equivalent to a direct resolution of the Navier-Stokes equations, no LRN models involved. After multiple tests, I came to the conclusion that the LB model code is not working right, impossible to duplicate any results found in references. Instead of using the LB model, I used a 2 layer LRN model (Xu-Chen) for my applications. Sorry I could not be of more help. Have a nice day. |
Nikesh Bhattarai
Thnx Jo.
I shall try that out too. Lets see how it goes!! |
epsilon, restivo |
Low Reynolds number k-E Turbulent Model | Sohail | FLUENT | 19 | July 16, 2020 14:08 |
Stability problem due to turbulent dispersion force in a subcooled boiling model | Edy | OpenFOAM | 7 | August 10, 2011 12:00 |
Turbulent SST model | fergal | CFX | 13 | November 2, 2010 18:15 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
Turbulent model in 2D calculations | Francisco Saldarriaga | Main CFD Forum | 1 | August 10, 1999 23:10 |
