July 4, 2011, 10:31 |
Heat transfer of liquids in a pipe
AV.
Rep Power: 15 |
Im trying to set my thermophysical properties for a liquid flow in a pipe with heat transfer. At first it can be incompressible and the flow laminar. (simpliest case just to learn). I did this simulation using buoyantSimpleFoam for gas (the default air properties of tutorials) using : thermoType hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>; It works well... Which thermoType should I use ? Maybe should I use BuoyantBoussinesqSimpleFoam instead buoyantSimpleFoam? Thanks for the attention guys |
July 4, 2011, 11:50 |
Nima Samkhaniani
Rep Power: 24 |
for laminar incompressible flow you can you can add:
scalarTransportFoam to icoFoam and compile it! or use buoyantBoussinesqSimpleFoam or buoyantBoussinesqPisoFoam |
July 4, 2011, 12:19 |
AV.
Rep Power: 15 |
Thanks for the answer guy,
Its a laminar , imcompressible flow with heat tranfer, so I would use boussinesqSimple. |
Pipe Flow Heat Transfer | Saima | CFX | 5 | January 30, 2011 16:41 |
Heat Transfer in a pipe flow(hot air) | Saima | Main CFD Forum | 0 | January 17, 2011 07:08 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
