two phase vof problem, problem with thermophysical properties
Old   March 11, 2011, 05:43
Default two phase vof problem, problem with thermophysical properties
karthik
karthik1414 is on a distinguished road
hello all,
I am new to openfoam and cannot figure out anything from the error
For calculating the thermophysicalproperties of the two phase vof problem, we used hRhoThermo, according to the example in tutorial link https://github.com/OpenCFD/OpenFOAM-...onLiquidHeater
we have included all the pointers, included specie in options,etc... and all that we can think of. But we are getting the error message as follows
--> FOAM FATAL ERROR:
Unknown basicRhoThermo type hRhoThermo<pureMixture<constTransport<specieThermo <hConstThermo<incompressible>>>>>
Valid basicRhoThermo types are:
6
hRhoThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
hRhoThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>
hRhoThermo<pureMixture<sutherlandTransport<specieT hermo<janafThermo<perfectGas>>>>>
hsRhoThermo<pureMixture<constTransport<specieTherm o<hConstThermo<perfectGas>>>>>
hsRhoThermo<pureMixture<sutherlandTransport<specie Thermo<hConstThermo<perfectGas>>>>>
hsRhoThermo<pureMixture<sutherlandTransport<specie Thermo<janafThermo<perfectGas>>>>>
i donot know what to do more. I cannot figure out what the error message is saying.
Perfect gas?? we are using a case for incompressible fluid flow, so why perfect gas?
Please advice us on the matter and help us out.
Thanks,
Warm regards,
Karthk
karthik1414 is offline   Reply With Quote
Old   March 11, 2011, 08:16
Matthias Voß
mvoss is on a distinguished road
did you try a "git pull" for the newest versions?
mvoss is offline   Reply With Quote
Old   March 14, 2011, 08:45
karthik
hey!
thanks for the advice, but i did not understand wht this gitpull is!!
thnks in advance!!
regards,
kar
Old   March 14, 2011, 08:51
Matthias Voß
git is a version control system.
i´ve had a similar error and solved it by a "git pull"...
you might wan´t to check here http://ww3.cad.de/foren/ubb/Forum527...5.shtml#000023 too...
Old   March 15, 2011, 07:49
karthik
will try that!!! thanks a lot!!
karthik
heat transfer, hrhothermo, two phase, vof
mass conservation problem with VOF model pat77 FLUENT 6 February 24, 2017 04:39
Extract primary phase thread in VOF with 3 phases Eric FLUENT 2 July 7, 2011 02:22
problem in VOF hamid1 FLUENT 7 February 5, 2011 00:32
Differences between VOF and phase field 2L Main CFD Forum 2 July 4, 2004 13:30
VOF problem Jarrod Sinclair Siemens 5 September 19, 2003 13:36
