two phase vof problem, problem with thermophysical properties |
March 11, 2011, 05:43 |
karthik
hello all,
I am new to openfoam and cannot figure out anything from the error For calculating the thermophysicalproperties of the two phase vof problem, we used hRhoThermo, according to the example in tutorial link https://github.com/OpenCFD/OpenFOAM-...onLiquidHeater we have included all the pointers, included specie in options,etc... and all that we can think of. But we are getting the error message as follows --> FOAM FATAL ERROR: Unknown basicRhoThermo type hRhoThermo<pureMixture<constTransport<specieThermo <hConstThermo<incompressible>>>>> Valid basicRhoThermo types are: 6 ( hRhoThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>> hRhoThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>> hRhoThermo<pureMixture<sutherlandTransport<specieT hermo<janafThermo<perfectGas>>>>> hsRhoThermo<pureMixture<constTransport<specieTherm o<hConstThermo<perfectGas>>>>> hsRhoThermo<pureMixture<sutherlandTransport<specie Thermo<hConstThermo<perfectGas>>>>> hsRhoThermo<pureMixture<sutherlandTransport<specie Thermo<janafThermo<perfectGas>>>>> ) i donot know what to do more. I cannot figure out what the error message is saying. Perfect gas?? we are using a case for incompressible fluid flow, so why perfect gas? Please advice us on the matter and help us out. Thanks, Warm regards, Karthk |
March 11, 2011, 08:16 |
Matthias Voß
Rep Power: 20 |
did you try a "git pull" for the newest versions?
March 14, 2011, 08:45 |
karthik
March 14, 2011, 08:51 |
Matthias Voß
Rep Power: 20 |
git is a version control system.
i´ve had a similar error and solved it by a "git pull"... you might wan´t to check here http://ww3.cad.de/foren/ubb/Forum527...5.shtml#000023 too... |
March 15, 2011, 07:49 |
#5 | |
karthik
karthik |
heat transfer, hrhothermo, two phase, vof |
mass conservation problem with VOF model | pat77 | FLUENT | 6 | February 24, 2017 04:39 |
Extract primary phase thread in VOF with 3 phases | Eric | FLUENT | 2 | July 7, 2011 02:22 |
problem in VOF | hamid1 | FLUENT | 7 | February 5, 2011 00:32 |
Differences between VOF and phase field | 2L | Main CFD Forum | 2 | July 4, 2004 13:30 |
VOF problem | Jarrod Sinclair | Siemens | 5 | September 19, 2003 13:36 |
