IDEA viscosity
Old   March 14, 2011, 07:33
Default IDEA viscosity
fairus
mfmohdyasin is on a distinguished road
Dear all,
I tried to plot the Dynamic viscosity of different fuels that are implemented in OpenFOAM using the function given in NSRDSfunc1.H and the coefficients given in liquids/IDEA.C.
Based on the plot that I attached, IDEA dynamic viscosity increases after about 550K which is not physical. Does anyone know about this issue?
Best
Fairus
mfmohdyasin is offline   Reply With Quote
Old   March 14, 2011, 11:54
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
Hmmm...I added that. I will look into it tomorrow.
niklas is offline   Reply With Quote
Old   April 7, 2011, 07:46
niklas's Avatar
Niklas Nordin
Its because the alphaMethyl napthalene properties are the way they are.
I have checked the numbers and they are correct as according to the NSRDS tables.
check the viscosity of aC11H10 and you will see how it looks.
for more info on how the idea fuel was constructed look into the file
src/thermophysicalModels/liquids/IDEA/IDEA.H
N
Old   April 7, 2011, 07:50
niklas's Avatar
Niklas Nordin
looking into the table again I see that the valid temperature range for the liquid viscosity is only
250-450 K, which might explain the behavior.
Eulerian Modeling: Frictional Viscosity Help meangreen FLUENT 1 January 25, 2018 15:13
Turbulence viscosity limited Madhukar Rapaka FLUENT 0 June 26, 2006 03:17
kinematic viscosity at diff temperatures,pressures Mecobio Main CFD Forum 0 November 7, 2005 12:55
Turbulent viscosity in a riser ap FLUENT 8 April 19, 2003 08:00
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
