How to access the field of weighting factor of interpolations
Old   November 15, 2012, 22:46
Default How to access the field of weighting factor of interpolations
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
I'd like to access and use the weighting factor used in interpolations.
When I use the setting "interpolate(U) linear", I'd like to access the
weighting factor w in the following equation:
U_f = w*U_P + (1-w)*U_N
Could you tell me how to access the field(maybe surfaceScalarField)
of the weighting factor for the interpolation schemes defined in fvSchemes?
Thanks in advance,
Fumiya
fumiya is offline   Reply With Quote
Old   November 16, 2012, 04:43
Lieven
Lieven will become famous soon enough
For linear interpolation "mesh.surfaceInterpolation::weights()" should work (surfaceScalarField).
Regards,
Lieven
Lieven is offline   Reply With Quote
Old   November 16, 2012, 07:33
fumiya's Avatar
Fumiya Nozaki
Thank you for your reply. That works fine for linear interpolation.
Is there a more general way to access weighting factors for other
interpolation schemes different from the central differencing?
Thank you for your help,
Fumiya
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Performance of GGI case in parallel hannes OpenFOAM Running, Solving & CFD 26 August 3, 2011 03:07
Access to Domain Pressure Field or mesh ar_mofidi OpenFOAM 0 April 12, 2010 06:47
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
