how to set the timevarying uniform value of internalField?
Old   April 3, 2011, 06:59
Default how to set the timevarying uniform value of internalField?
Jianxi Yao
jianxiyao is on a distinguished road
does someone knows how to set the internalField value which vary with time in an unsteady simulation? i know that there is a timeVaryingUniformFixedValue for BC,but which one for internalField?
jianxiyao is offline   Reply With Quote
Old   April 4, 2011, 03:06
Samuel ARNAUD
sixwp is on a distinguished road
Hi Jianxi,
you don't have to put a time varying value for the internalField as it already behaves like this.
Put an "uniform value" in /0 folders and it will vary by itself during the calculation.
Sam
sixwp is offline   Reply With Quote
Old   April 4, 2011, 04:23
Jianxi Yao
thank you Sam! my computational model is that a body move in a field with a constant velocity in the x direction but in the y direction with a time-varying velocity. So i just have to set a time-varying boundary conditions but not the internalfield values?
Old   April 4, 2011, 16:58
Fran
lfbarcelo is on a distinguished road
InternalField is not a boundary condition, it's an INITIAL condition. Which means that it's set only at the begining and re-calculated during the simulation.
If you have constant speed in the x direction, set a constant speed BC on your x-normal inlet wall.
To set the time varying BC in the Y direction, set the Y speed vasying BC on one of your Y-normal walls, and set the pressure on the opposite Y-normal wall.
This may not converge, y recommend that you have some fixed walls in your model, separating the different inlet and outlet patches. I'll upload a drawing to explain myself
lfbarcelo is offline   Reply With Quote
Old   April 5, 2011, 03:33
Jianxi Yao
Hi Lfbarcelo
i will try it. i hope that can work. thanks!
Cht tutorial in 15 braennstroem OpenFOAM Running, Solving & CFD 197 June 10, 2015 03:02
Dealing with BC's in OF 1.6 vkrastev OpenFOAM Running, Solving & CFD 5 September 4, 2012 11:58
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Flow Around a Cylinder ronaldo OpenFOAM 5 September 18, 2009 08:13
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
