Inlet and Outlet
Old   April 11, 2011, 13:49
Default Inlet and Outlet
Luis Blanes
lmblanes is on a distinguished road
Hi All
I am trying to setup a simple case with an Inlet and an Outlet.
I am used to WinAir, where you only input a Volumetric Flow (m3/s) and a directional Vector.
I am reviewing the Derived Patch Field Types...but I am confused about which one to use.
Could anyone help me on that?
Thanks
Another question I have is about the relationship between solvers and the different Patch Field Types.( I am using buoyanBoussinesqSimpleFoam, and the other steady state solver dealing with heat Transfer for buoyancy driven flows...)
Can I use anyone of the patch fields described in page U-133 ? or are they linked to a precise solver?
Thanks
Luis Blanes
lmblanes is offline   Reply With Quote
Old   April 11, 2011, 15:13
Default Errors regarding Inlet and Outlet
Luis Blanes
Hello all
I tried to run a simulation with the following values at the U/0 directory
boundaryField
warm
type fixedValue;
value uniform (0 0 0);
cool
type fixedValue;
defaultFaces
type fixedValue;
inlet
type fixedValue;
value uniform (0 0 -1);
outlet
type fixedValue;
value uniform (0 0 1);
And I got that error.
Can somebody please help me?
Thanks
Can I input just two velocities in a patch just typing that in the U/0 directory??
Can the velocity vector point outside the domain??
Thanks
Starting time loop
Time = 0.1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.00451649, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 8.88538e-17, No Iterations 1
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam:ILUPreconditioner::calcReciprocalD(Foam::Fi eld<double>&, Foam::lduMatrix const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam:ILUPreconditioner:ILUPreconditioner(Foam: :lduMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#5 Foam::lduMatrix:reconditioner::addasymMatrixCons tructorToTable<Foam:ILUPreconditioner>::New(Foam ::lduMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#6 Foam::lduMatrix:reconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#8 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libfiniteVolume.so"
in "/opt/openfoam171/applications/bin/linuxGccDPOpt/buoyantBoussinesqSimpleFoam"
#10 __libc_start_main in "/lib/libc.so.6"
#11
Floating point exception
Old   April 12, 2011, 05:49
Arnout
The King is on a distinguished road
Try to use zeroGradient for your outflow. Is the direction of the velocity in your inlet ok?
The King is offline   Reply With Quote
Old   April 12, 2011, 06:09
Luis Blanes
Thanks The King.
Yes, the direction in the Inlet makes no sense.
I guess that you only need to input a velocity in the inlet and zeroGradient in the outlet.
Thanks
Old   April 12, 2011, 06:51
Default Inlet velocity is ok....
Luis Blanes
I have checked the case again...
I use buoyantBoussinesqSimpleFoam
Can anyone tell me how to input a simple Inlet and Outlet in using heatTransfer solvers?
U at inlet is ok (0 0 -1) as it is pointing inside the domain (can I use negative numbers?)
Thanks in advance
boundary file
5
warm
type wall;
nFaces 390;
startFace 90580;
cool
type wall;
nFaces 390;
startFace 90970;
inlet
type patch;
nFaces 1;
startFace 91360;
outlet
type patch;
nFaces 1;
startFace 91361;
defaultFaces
type wall;
nFaces 5270;
startFace 91362;
U/0
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
warm
type fixedValue;
cool
type fixedValue;
defaultFaces
type fixedValue;
inlet
type fixedValue;
outlet
type zeroGradient;
p/0
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
warm
type buoyantPressure;
rho rhok;
value uniform 0;
cool
rho rhok;
value uniform 0;
defaultFaces
rho rhok;
value uniform 0;
inlet
rho rhok;
value uniform 0;
outlet
rho rhok;
value uniform 0;
Old   April 13, 2011, 05:47
Dominic
351Cleveland is on a distinguished road
Hi lmblanes
Just wondering a little about your pressure setup. You might try keeping the outlet/internalField at uniform 0 and setting the rest to zeroGradient. My experience is only really with simpleFoam, so I hope this helps.
Also, yes you can use negative numbers for velocity as long as you're sure its in the right direction.
Dom
351Cleveland is offline   Reply With Quote
Old   April 13, 2011, 05:57
Luis Blanes
Thanks!
I have seen lots of cases where there is an Inlet and the "Outlet" is just a free pressure boundary...
What do you mean with "in the right direction"? Is there some rule?
I wonder if I can do something like this
________________
I I
I I
Inlet(1m3/s) ---> Outlet(0.9 m3/s) --->
I I
I I
I Opening to atmosphere
I_______________ I
Thanks
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
total pressure boundary problem ==> flow from outlet to inlet!! mrshb4 OpenFOAM 0 November 20, 2010 12:41
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 06:52
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 08:07
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
