machines file for running applications in parallel
Old   April 14, 2011, 03:59
Default machines file for running applications in parallel
tH3f0rC3 is on a distinguished road
I'm searching for a correct machines file to run an application in parallel.
I want to run with two cpu's.
I still have read this.
So I have created the decomposepart and a machines file.
I have attached the two file I have created.
I have also attached the errormessage.
I would be happy about suggestions how to solve.
Best Regards,
tH3f0rC3
tH3f0rC3 is offline   Reply With Quote
Old   April 14, 2011, 08:52
Default decomposePar
Fabian Roesler
fabian_roesler is on a distinguished road
Hi tH3f0rC
your decomposePar file is incorrect. As you want to use 2 CPUs and the simple decomposing method, you have to split the domain in 2 regions (not in 4). The correct decomposePar should look like this:
numberOfSubdomains 2;
method simple;
simpleCoeffs
n ( 2 1 1 );
delta 0.001;
hierarchicalCoeffs
n ( 1 1 1 );
delta 0.001;
order xyz;
metisCoeffs
processorWeights ( 1 1 );
manualCoeffs
dataFile "";
distributed no;
roots ( );
the simple method splits the simulation domain in 2x1x1 regions corresponding to the number of the CPUs used.
As you work on one machine, you do not need a machine file. Just use the decomposePar and the mpirun afterwards.
Hope this helps.
Regards
Fabian
fabian_roesler is offline   Reply With Quote
Old   April 14, 2011, 09:20
Hey thanks!
This helped a lot.
So now only one thing is left to mpirun the file.
I don't know the command I have to type in (in command line).
In OF docs there is only used a command with machines.
Can you also help my with that?
Best Regards,
tH3f0rC3
Old   April 14, 2011, 09:54
Default mpirun on one machine
Fabian Roesler
Hi tH3f0rC3
with the command
mpirun -np 2 icoFoam -parallel
you start a multi processor run on 2 cores using the solver icoFoam in parallel. No log file is produced.
After the run you have to use reconstructPar. This should be all.
Best wishes
Fabian
Old   April 14, 2011, 10:07
Hey, thank you very much.
Now it works!!! :-)
Best Regards,
tH3f0rC3
Old   April 19, 2011, 06:50
Hi Fabian,
I have now tried to use reconstructPar the solved files. The problem ist that I use the chtMulti-solvers, where the directories are stored different than in icoFoam.
so there is the folliwing error-message appearing:
--> FOAM FATAL ERROR:
Cannot find file "points" in directory "polyMesh" in times 0 down to constant
This is due to the directorys air, solid into the 0, constant and system directories.
Do you know how can solve this? In every processor (p0 and p1) directory there are files from 0 to 100. (controldict: endtime: 100)
If I copy these files into the case-directory I have only the files from processor0. But how to proceed with the files in processor1? I can only overwrite them manually and this can not be the solution.
Best Regards,
tH3f0rC3
Old   April 19, 2011, 10:38
Default chtMultiRegionFoam -parallel
Fabian Roesler
Hi tH3f0rC3
I think you have to reconstruct every region for its own. So use something like:
reconstructPar -region air
reconstructPar -region solid
Although the visualization in Paraview is different to normal cases. You can have a look to the ./Allrun script in the tutorial. Hope I could help.
Best wishes
Fabian
Old   April 19, 2011, 13:21
Hi tH3f0rC3
Best wishes
Fabian
What do you mean exactly? Do you refer to a case which was solved in parallel? Because I don't know that a tutorial exists where a case solved in parallel is shown?!
Or do you refer to the chtMulti-solver?
Yes, your answer was very helpful!
Best Regards,
tH3f0rC3
Old   April 19, 2011, 20:43
Retired Super Moderator
Bruno Santos
Greetings to all!
@Luke Skywalker Please study this script:
tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/Allrun
The part that I think you are looking for right now is near the end of the script:
# Reconstruct
for i in bottomAir topAir heater leftSolid rightSolid
do
   reconstructPar -region $i > log.reconstructPar.$i 2>&1
done
echo
echo "creating files for paraview post-processing"
echo
do
   paraFoam -touch -region $i
done
May the force be with you.
Bruno
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
openfoam 1.6 on debian etch romant OpenFOAM Installation 9 May 6, 2010 02:26
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
