How to make blockMesh file of this mesh?
Old   April 15, 2011, 10:19
Default How to make blockMesh file of this mesh?
LT
NewKid is on a distinguished road
Hi, everyone, I run into a problem of making blockMeshDict file of such a mesh in attachement:
In fact, the edge between point 17 and 8 should be a arc, but hard to draw it, I draw a line indeed.
PS: I split the whole block into 3 sub-blocks along Z-axis, and those red dash lines show the edge of each sub-blocks.
How to make the correct blockMeshDict file of this mesh or any better way to split the whole block?
Thanks!
NewKid is offline   Reply With Quote
Old   April 15, 2011, 10:36
Andrea Pasquali
andrea.pasquali is on a distinguished road
Maybe you can follow the blockMeshDict.m4 inside the MRFSimpleFoam tutorial.
You have to write a .m4 file and run it to obtain the blockMeshDict.
regards
Andrea
Andrea Pasquali
andrea.pasquali is offline   Reply With Quote
Old   April 16, 2011, 03:24
LT
.m4 file?
I'll check it ASAP.
Thanks!
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
