Boundary conditions for potentialFoam
Old   May 7, 2011, 02:59
Default Boundary conditions for potentialFoam
doubtsincfd is on a distinguished road
How can I specify boundary conditions for potentialFoam in terms of velocity potential? Or how can a dirichlet boundary condition for velocity potential be implemented in potentialfoam?
doubtsincfd is offline   Reply With Quote
Old   May 8, 2011, 04:05
Nima Samkhaniani
nimasam is on a distinguished road
is in the dirichlet boundary condition the value of velocity fixed or zero at boundary conditions? so use
type fixedValue;
value uniform (0 , 0 , 0);
nimasam is offline   Reply With Quote
Old   May 8, 2011, 04:33
I want to specify phi=constant boundary condition. Is there any way to specify boundary condition for phi? As per my understanding, it writes the phi values after convergence. We can only input U and P values.
Old   May 8, 2011, 09:44
Nima Samkhaniani
as i know phi = U & mesh.Sf() so when U is fixed at the boundary phi should be fixed too
Old   May 8, 2011, 14:26
Thank you. What does "U & mesh.Sf()" exactly mean mathematically? I am not aware of the syntax used in source code of openfoam. d(phi)/dn = Un, so does U & mesh.Sf() integrate U to get phi?
Also How do I then calculate U so that I get desired value of phi ? Do I have to go for trial and error?
Old   May 8, 2011, 15:13
Nima Samkhaniani
phi = U & mesh.Sf()
U= velocity vector
& = inner product
mesh.Sf() = normal surface vector
i guess you just need to divide ur desired phi into ur boundary area cross section,so you have desired U
then evaluate U in dict!
Old   May 16, 2011, 22:14
Basic confusion:
is phi flux or velocity potential?
Old   May 17, 2011, 04:11
Nima Samkhaniani
its flux
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 09:38
Pressure boundary conditions Lionel S. Main CFD Forum 1 August 24, 2007 18:03
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
