Where do we read relaxationFactors in fvSolution in the codes?
Like Tree1Likes
  • 1 Post By marupio
Old   May 24, 2011, 05:34
Default Where do we read relaxationFactors in fvSolution in the codes?
Kai
kaifu is on a distinguished road
Hi Foamers,
I am curious about where do we read relaxationFactors in system/fvSolution in the solvers? For example, in simpleFoam, I can not see any dictionary is defined to look up those numbers. I guess it may read those numbers when we are trying to solve eqns. For example, in "UEqn.H", does the line
UEqn.relax();
read the relaxation factor for U?
Thx
// Kai
kaifu is offline   Reply With Quote
Old   May 24, 2011, 11:13
Kai
It is said "The user can specify the relaxation factor for a particular field by specifying first the word associated with the field, then the factor. The user can view the relaxation factors used in a tutorial example of simpleFoam for incompressible, laminar, steady-state flows."
It is not clear how to update the field during calculation although it seems that the relaxation factor is connected with the particular field automatically.
For example, if I create a field Gamma, and it will be updated every interation, say,
Gamma=a value
Then how does the solver deal with the updated Gamma and its relaxation factor?
Even for the alpha, U, p, k, epsilon, after solving the PDEs,
alphaEqn.solve();
will they be relaxed with the factor implicitly and automatically?
// Kai
Old   May 24, 2011, 13:41
David Gaden
marupio is on a distinguished road
I was just reading up on that myself.
Relaxation factors are specified in the controlDict file, under a subdictionary called 'relaxationFactors'. It contains a list of field names, with the associated relaxation factors.
eg. (and I'm guessing a little here):
relaxationFactors
    U    0.7;
    T    0.5;
If the field name is not found, no relaxation is applied.
marupio is offline   Reply With Quote
Old   May 24, 2011, 15:45
Kai
But when do you use those numbers? For example to solve UEqn, you will use
UEqn.relax();UEqn.solve();
I dont see any relax factor is used.
// Kai
Old   May 24, 2011, 15:54
David Gaden
fvMatrix::relax is overridden. If you provide it with a scalar - relax(factor) - it will relax the matrix with the given factor. If you don't, here's what it does:
From fvMatrix.C:
template<class Type>
void Foam::fvMatrix<Type>::relax()
    if (psi_.mesh().relax(psi_.name()))
        relax(psi_.mesh().relaxationFactor(psi_.name()));
It calls the overridden relax(factor) function, feeding it a scalar that was looked up in the controlDict. psi_.mesh().relaxationFactor(word) is a function in the solution class, which is part of the mesh. solution holds all the relaxation factors, which it reads from controlDict in the format I specified above.
You could figure this out from reading the source code, which is a little tricky until you get used to it. From a practical perspective, you can use relax by either putting:
PEqn.relax()  // Look up factor from controlDict
PEqn.relax(factor)  // Use the factor provided
If using the first one, the user has to have a relaxationFactors subdictionary in the controlDict to get it to work.
Am I answering the question?
C. Okubo likes this.
Old   May 24, 2011, 16:07
Kai
That's great! Thanks
Is it worth it? Jason Bardis Main CFD Forum 47 July 27, 2011 04:52
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
Comparison of CFD Codes Kerem Main CFD Forum 9 May 9, 2003 04:29
New List of Free CFD Codes Bert Laney Main CFD Forum 5 September 15, 1999 15:24
Anyone used Ansys/Flotran - cf. with other codes? S. Langsford Main CFD Forum 3 October 19, 1998 20:51
