June 7, 2011, 05:29 |
change fixedGradient BC during run
fisch
Rep Power: 16 |
i want to change my boundary conditions during the run of my solver. So specifying Dirichlet BC was more or less easy to implement (overwriting the boundaryFields of the variables). Now I want to overwrite the value of the fixedGradient BC during the runtime for other variables. Is this possible and easy to access? Thank you for any advice, rupert |
June 7, 2011, 10:16 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
June 7, 2011, 10:41 |
fisch
Rep Power: 16 |
thanks bernhard for the quick reply,
there are unfortunately questions left: Is there no problem using the groovyBC specifying values for "valueExpression" and for "gradientExpression" ??? I thought that it is the only way to specify (e.g. using) simpleFoam either the velocity as dirichlet and the pressure as neumann or the other way around. Now it seems that i can specify on both fields dirichlet and neumann!? Can you explain that to me? One more thing: What is, if i dont specify one of these two keywords ( "valueExpression" or "gradientExpression)?? thanks a lot, rupert |
June 8, 2011, 06:53 |
#4 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
http://openfoamwiki.net/index.php/Co...s_in_the_patch |
June 8, 2011, 12:34 |
fisch
Rep Power: 16 |
Thanks a lot Bernhard,
it seems that it works. rupert |
fixedGradient BC type with the channelOodles solver | Bedotto | OpenFOAM Running, Solving & CFD | 5 | April 15, 2019 09:49 |
How to change density in OpenFoam | zhaowei | OpenFOAM Running, Solving & CFD | 8 | November 5, 2018 10:37 |
Change cell zone index/thread during simulation | neilduffy1024 | FLUENT | 0 | January 17, 2011 09:40 |
Windows 64-bit, Distributed Parallel Run Issues... | Erich | CFX | 3 | March 28, 2006 16:36 |
problems with LES run | Tim | CFX | 1 | February 27, 2006 07:28 |
