Extending Libraries
Old   June 27, 2011, 00:20
Default Extending Libraries
venkat
venkataramana is on a distinguished road
hi everyone,
The OpenFOAM software includes over 80 shared libraries containing a range of functionality for numerics, linear solvers, modelling, meshing, post-processing, etc. Libraries are designed to be conveniently extended with the following feature helping to make the task easier.
Dynamic linking of libraries When a new library is created, it does not need to be linked directly into applications wishing to use its functionality. Instead, the user can dynamically link the library at run-time, through a setting in the case controlDict file. I want to create a new scheme or implementation of existing scheme in openfoam,
can anybody applied the above method, if so please write the procedure for doing so,thanks in advans,
Regards,
venkataramana is offline   Reply With Quote
Can't profile shared libraries rsamuel OpenFOAM Programming & Development 1 August 3, 2009 09:58
Installation/Tutorial - libraries not found (blockMesh) bernarde OpenFOAM 3 June 19, 2009 12:36
Fortran90 (creating executable by using libraries) Ravi Main CFD Forum 0 September 27, 2004 22:34
help on POOMA/PVM etc. libraries mayank Main CFD Forum 0 November 14, 2002 23:04
More advise on libraries to solve linear system Ricardo Bonon Main CFD Forum 0 May 18, 2000 18:37
