Foam::sigFpe::sigFpeHandler(int) Error
Like Tree1Likes
  • 1 Post By usergk
Old   April 20, 2011, 00:17
Default Foam::sigFpe::sigFpeHandler(int) Error
usergk is on a distinguished road
I am trying to implement combustion in OpenFOAM and I get the error below. This happens mid-way during the simulation, after a few time steps.
Any idea why this could be occurring? I am relatively new to using OpenFOAM, so any information would be appreciated.
Thanks!
gk
[24] #0 Foam::error:rintStack(Foam::Ostream&) in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[24] #1 Foam::sigFpe::sigFpeHandler(int) in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[24] #2 in "/lib/libc.so.6"
[24] #3 in "/lib/libm.so.6"
[24] #4 pow in "/lib/libm.so.6"
[24] #5 Foam::ODEChemistryModel<Foam:siChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam:erfectGas> > > >:mega(Foam::Reaction<Foam::sutherlandTransport< Foam::specieThermo<Foam::janafThermo<Foam:erfect Gas> > > > const&, Foam::Field<double> const&, double, double, double&, double&, int&, double&, double&, int&) const in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libchemistryModel.so"
[24] #6 Foam::ODEChemistryModel<Foam:siChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam:erfectGas> > > >::tc() const in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libchemistryModel.so"
[24] #7
[24] in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/pFoam"
[24] #8 __libc_start_main in "/lib/libc.so.6"
[24] #9
[node69:00818] *** Process received signal ***
[node69:00818] Signal: Floating point exception (8)
[node69:00818] Signal code: (-6)
[node69:00818] Failing at address: 0x58f800000332
[node69:00818] [ 0] /lib/libc.so.6(+0x33af0) [0x2b0cdf0abaf0]
[node69:00818] [ 1] /lib/libc.so.6(gsignal+0x35) [0x2b0cdf0aba75]
[node69:00818] [ 2] /lib/libc.so.6(+0x33af0) [0x2b0cdf0abaf0]
[node69:00818] [ 3] /lib/libm.so.6(+0x13e81) [0x2b0cdebf0e81]
[node69:00818] [ 4] /lib/libm.so.6(pow+0x15) [0x2b0cdec02765]
[node69:00818] [ 5] /home/gk/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libchemistryModel.so(_ZNK4Foam17ODEChemistryModelI NS_17psiChemistryModelENS_19sutherlandTransportINS _12specieThermoINS_11janafThermoINS_10perfectGasEE EEEEEE5omegaERKNS_8ReactionIS8_EERKNS_5FieldIdEEdd RdSI_RiSI_SI_SJ_+0x285) [0x2b0cdd978ff5]
[node69:00818] [ 6] /home/gk/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libchemistryModel.so(_ZNK4Foam17ODEChemistryModelI NS_17psiChemistryModelENS_19sutherlandTransportINS _12specieThermoINS_11janafThermoINS_10perfectGasEE EEEEEE2tcEv+0x57e) [0x2b0cdd98424e]
[node69:00818] [ 7] pFoam() [0x426bf3]
[node69:00818] [ 8] /lib/libc.so.6(__libc_start_main+0xfd) [0x2b0cdf096c4d]
[node69:00818] [ 9] pFoam() [0x421119]
[node69:00818] *** End of error message ***
usergk is offline   Reply With Quote
Old   April 22, 2011, 23:53
Can anyone explain why this floating point error may be occurring?
Thanks,
gk
Old   July 5, 2011, 09:22
jabecker is on a distinguished road
Hello usergk,
Did you ever figure out the issue? Your help would be greatly appreciated. It seems like the error is generally caused by having an initial condition set wrong, but I cannot seem to figure out why mine is not correct. When I have things set as zero, I want them to be set as zero. Mine comes from a slightly different thermophysicalProperties folder, but I would imagine it is caused from the same problem. My error reads:
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/opt/openfoam170/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#4 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::hPsiThermo(Foam::fvMesh const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#5 Foam::basicPsiThermo::addfvMeshConstructorToTable< Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#6 Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
in "/opt/openfoam170/applications/bin/linux64GccDPOpt/chtMultiRegionFoam"
I really hope you can help! Thanks in advance,
Jen
jabecker is offline   Reply With Quote
Old   July 5, 2011, 09:52
Hi Jen,
Some of the possible ways:
Initial conditions be more accurate
Mesh may need to be improved
Change fvSchemes/fvSolution files - There are some posts on the forum that talk about this (esp when k/epsilon blows up)
gk
xiaobao_jia likes this.
Old   July 5, 2011, 10:10
Hello gk,
Thank you for your quick response! I have another question: Do you work with chtMultiRegionFoam? This is the program I am currently working with and it is giving me quite the headache. I found out that the issue was indeed a zero condition in the initial folder that should not be set as zero, but this is not what I had set it as. My initial conditions for my topAir get completely changed when I use ./Allrun and this is where the error comes from. The only way I can get the program to get rid of this error is by running ./Allrun and then completely changing my 0/topAir files all over again. It seems really strange, but I cannot figure out why it is replacing all of the folders.
Your help again would be greatly appreciated. Thanks,
Jen
Old   July 5, 2011, 10:31
Sorry, I don't use this particular solver. You can try searching on the forum for similar issues (assuming you haven't already).
Best,
gk
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
