July 7, 2011, 14:19 |
Setting the Velocity Field
Andrew
I am working on a project in which air speed readings will be taken around a room using handheld anemometers, and then that data will be collected and plugged in to simulate the airflow in a room (a fan will be used to stimulate the flow). I have been trying to use OpenFOAM to set up a model of a room and set air velocity at different points in the mesh, but have not been able to figure out how to do it. While researching this problem, I have just found how to set the velocity field at the boundary, which is not what I am aiming to do. How can I set the velocity field at different points within my mesh?
July 8, 2011, 02:15 |
Bernhard
Rep Power: 21 |
If you have a fan at those locations, then you need a source term for momentum in the Navier-Stokes equations. Just 'setting' the velocity, is not a viable approach in my opinion.
velocity field |
Cartesian to cylindrical velocity field conversion | francois | OpenFOAM Post-Processing | 11 | November 30, 2017 05:52 |
real velocity field from energy spectrum | Angel | Main CFD Forum | 7 | December 13, 2013 20:40 |
accessing another velocity field in bc | daviderzen | OpenFOAM | 0 | April 20, 2011 06:24 |
how to simulate velocity field of supersonic gas (400m/s) from a nozzle to a chamber | CYMa | OpenFOAM | 3 | December 15, 2009 21:31 |
Reconstruction of velocity and pressure field | Jianglan | Main CFD Forum | 0 | October 6, 2008 00:04 |
