Ideal Gas Law Overspecification
Old   July 8, 2011, 16:53
Default Ideal Gas Law Overspecification
Cyberholmes is on a distinguished road
I was wondering, in the OpenFOAM solver buoyantPimpleFoam, you specify the pressure and temperature in the initial conditions, the volume by creating the geometry that you mesh, and the number of moles of gas in the thermophysicalProperties file. Because of this, you have specified every variable in the equation
pV=nRT.
Isn't this overspecification? Why does the solver not return an error if your set conditions do not adhere to this law, and what are the effects on the solution if they don't?
Thank you.
Cyberholmes is offline   Reply With Quote
Old   July 11, 2011, 03:17
Lorenzo A. Ricciardi
lichmaster is on a distinguished road
I don't know what equations does buoyantPimpleFoam solve, however I bet you're not specifying V with the mesh, since V in the perfect gas laws is a specific volume (inverse of density)... setting P, T and n you can solve for local values of V (or rho, if you prefer), and no overspec occours
lichmaster is offline   Reply With Quote
Old   July 11, 2011, 10:34
Except that's not the case in the following formula:
pV=nRT.
The volume is a specific volume in the equation
p V_specific = R_specific T.
However, in pV=nRT, p is absolute pressure, V is volume of the chamber (not specific), n is number of moles, R is the molar gas constant, and T is the temperature. Every value in that equation is specified in the solver.
Old   July 11, 2011, 10:58
Thumbs down
Christian Lucas
Chris Lucas is on a distinguished road
the number of moles within the control volume (grid) is NOT specified. The number of moles you specify in the thermophysical properties is used for mixtures only. The perfect gas law is used to get the density.
Hope this helps
Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   July 11, 2011, 11:35
I'm sorry, but what do you mean by 'used for mixtures only'? What exactly is that number of moles specifying?
Old   July 12, 2011, 04:04
Cyberholmes,
I always work with specific or intensive dimensions, so n for me is moles/kg, and thus volume becomes a specific volume also... You're also right, it just depends how you're used to work...
Old   July 12, 2011, 10:46
The question though is how is OpenFOAM working?
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Using ideal gas law and sutherland law in Fluent RyGuy FLUENT 4 June 28, 2012 02:07
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Help!! calculate gas density by ideal gas law Mahe Phoenics 1 January 26, 2010 03:57
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
