February 17, 2012, 11:45 |
Negative pressure
Pierre Castellani
Rep Power: 14 |
I am trying to make my simulation working as best as possible and I get a strange result using rhoSimpleFoam! After several simulation the presure become highly negative: : Averages of p : inlet0 = -407441 : I'am using the utility patchAverage of simpleFunctionObjects. The presure is defined at the outlet and made zeroGradient at inlet. The velocity inlet is using flowRate. Strange no? Thx |
February 17, 2012, 11:54 |
Niklas Nordin
Rep Power: 29 |
what is the defined pressure at the outlet?
what are the relaxation factors? what is the initial velocity? what is the initial turbulent length scale? what is the outlet bc for velocity? just to name a few influential factors. ...and its not uncommon to get un-physical values early in the convergence. |
February 17, 2012, 12:35 |
Pierre Castellani
Rep Power: 14 |
Thanks for your very quick reply, I am (still!!) trying to simulate a vortex tube, I have attached my set up in 0 directory. I reduce the relaxation factor of p from 0.3 to 0.05! For the turbulent lenght scale, are talking about the one that should be used into the calculation of k and epsilon? If it is the case after several (dozens ;-) ) test I put a simple value for both of them even if I see how to calculated them, sorry for that!
Many thanks, Pierre. |
February 2, 2015, 10:54 |
zahra rashidi
Rep Power: 11 |
HI,i am intrested to simulate the vortex tube too,do you do that?
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
seeking for help about a room with negative pressure | mengyue1 | FLUENT | 0 | November 26, 2009 06:40 |
negative pressure in cfx | flar.t | CFX | 1 | December 18, 2006 23:20 |
negative pressure | mAx | FLUENT | 0 | January 25, 2006 14:31 |
