fanPressure BC
Like Tree12Likes
Old   August 17, 2011, 10:54
Default fanPressure BC
Sylvain Aguinaga
Sylvain is on a distinguished road
Hi everybody,
I'm now looking in using the new fanPressure BC introduced in 2.0.0 as I'm not satisfied with the classical fan BC. As far as I have understood this BC prescribes a total pressure jump based on the averaged velocity and pressure over the whole BC surface. I think that it would yield to a much more stable BC than the classical fan BC.
I have tested it in two configurations:
1) I make two cyclic patches using the createBaffle utility like for a classical fan condition. When I run simpleFoam the code says:
--> FOAM FATAL IO ERROR:
inconsistent patch and patchField types for
patch type cyclic and patchField type fanPressure
Indeed if you look into the code, the fanPressure BC is derived from the totalPressure BC which is a type patch. So I moved for the second configuraiton, with two distinct patches fan_upstrem and fan_downstream.
Then, when i run the code it says:
--> FOAM FATAL ERROR:
Attempt to cast type patch to type lduInterface
OK, but if one searches for lduInterface in your favorite CFD forum, one can find that this error means that your patches have to be declared as cyclic.....
So is FanPressure a cyclic BC like fan, or a patch BC like totaPressure? Is anybody succeed in using this BC?
Thanks ahead for your comments
Sylvain
Sylvain is offline   Reply With Quote
Old   August 17, 2011, 11:58
Sylvain Aguinaga
I've found my mistakes... actually I forgot to modify the other variables (U, k, omega) which were still defined as cyclic... which explains the FATAL ERROR. Sorry to bother you with such a lack of focus from me.
So for the record, the fanPressure BC works exactly as the totalPressure BC. I copied the totalPressure BC setup from the pimpleFoam/TJunction Tutorial. only the p file as to be modified with the example given in the .H file of the source code.
Warning: the code will ask you for the gamma constant ( totalPressure legacy ?)
fan_uptream
type fanPressure;
patchType totalPressure;
fileName "./constant/fanCurve"; // Fan curve file name
outOfBounds clamp; // (error|warn|clamp|repeat)
direction out; // Direction of flow through fan
p0 uniform 0; // Environmental total pressure
value uniform 0; // Initial pressure
gamma 1;
fan_downstream
type fanPressure;
direction in; // Direction of flow through fan
gamma 1;
Results look nice!!!
Thanks everybody for all your work posted in this forum.
Cheers
Sylvain
Old   August 23, 2011, 09:06
Claudio
claco is on a distinguished road
Hi Sylvain,
can You please explain me exactly what is the format of the "fanCurve" file? What have I to insert into this file?
Yours Sincerely,
Claudio
claco is offline   Reply With Quote
Old   August 24, 2011, 05:15
Sylvain Aguinaga
The fan curve is a table which links the delta_p to your averaged velocity through the fan...
Here is an example of what I have prescribed in my example
5 // five points in the table
(5 100) //(velocity pressure_jump)
(10 400)
(20 600)
(30 400)
(40 50)
I put this file into the constant folder.
I am thinking about this BC compared to the classic fan one. Its main advantage is that it is more "stable' than the classic one and that you can prescribe other BCs for the other variables such as k or omega.
From what I understood it is clearly designed as an "outlet" and "inlet" BC of your domain, and not as a "baffle" BC like in your case (and mine), which is the purpose of the classic fan BC.
However from my tests it looks like it also working well as a "baffle BC" provided you have only one single fan in the domain. If you have more than one fan, it is not working any longer as the inlet and outlet patch are not "connected" together. As a consequence you don't have the mass conservation through one fan (but you got it through the whole array of fan, of course, kind of redistribution of the mass flux between the fans)
I'm really interested in any feedback about those fan conditions. From my tests, you obtain results which are very differents when switching from one BC to another...
from my point of view, it would be nice to have the best of both worlds... a more constrain cyclic BC with specs on the variables and prescription of the pressure jump on the whole patch instead of each cells... to be continued...
Sylvain
mgg and davibarreira like this.
Old   August 24, 2011, 05:23
Claudio
Thank You,
the problem is that I have to prescribe a deltaP for each cell (that is, the deltaP varies radially according to a variation law). Moreover, this deltaP is independent from the velocity, it is constant, a value which remains fixed during the simulation. I know for each cell of the patch the deltaP, but I cannot understand how to specify those values (a nonUniform list).
Claudio
Old   August 24, 2011, 05:40
Sylvain Aguinaga
well I think you may have two solutions using a total pressure BC :
1) you are prescribing the ptot profile using using groovyBC
2) you program a little utility which "map" a non uniform ptot on the you patch
Sylvain
Old   August 24, 2011, 08:56
Claudio
Sylvain
Sorry,
but I meant a delta of static pressure, non a jump of totalPressure. In the fanPressure, do I have to impose a delta(static)P, or a delta(Total)P?. Because I only know the jump of static pressure, I have no infos about total pressure variation through the fan.
Claudio
Old   October 26, 2011, 10:57
maddalena's Avatar
maddalena
maddalena will become famous soon enough
Hello Sylvain and thank you for your contribution!
fan_uptream
type fanPressure;
gamma 1;
fan_downstream
type fanPressure;
gamma 1;
(10 400)
(20 600)
(30 400)
(40 50)
I am wandering what the BC should be on U on the boundaries declared as fanPressure. I cannot use fixedValue, since this would set the massflow, which should be selected according to fanCurve. zeroGradient is not ok as well, since it will not keep the velocity on the downwind side of the fan. Thus? what I should specify?
thank you!
mad
maddalena is offline   Reply With Quote
Old   October 26, 2011, 12:16
Sylvain Aguinaga
Hello Maddelana,
here is what I prescribed for U:
 fan_aval
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
    fan_amont
        type            inletOutlet;
        inletValue      uniform (0 0 0);
I have to admit I didn't look too deep inside the code for the "pressureInletOutletVelocity", as far as i understand it prescribes a flow rate which depends of the delta_p at the (inlet/outlet). Maybe I should have prescribed the same at the outlet. I didn't tried it yet.
Let me know if it worked for you
hope it'll be helpful
Sylvain
Old   October 31, 2011, 08:33
Default Hello Sylvian,
supercommandodhruv
dhruv is on a distinguished road
Hi Sylvian,
I am also doing some simulation involving a fan in the wind tunnel. I was hoping to use the fanPressure BC that you have described here. However, when I used them for pressure inlet and outlet patch , these BC is not recongnized in OF 2.0.0. OF throws a list of BCs, which has fan but not fanPressure.
Can you please tell me how you did it?
Regards,
Dhruv.
fan_uptream
type fanPressure;
gamma 1;
fan_downstream
type fanPressure;
gamma 1;
Cheers
Sylvain
dhruv is offline   Reply With Quote
Old   November 10, 2011, 08:21
Cesar Retamal Bravo
Curico is on a distinguished road
Hi Sylvian,
quisiera saber como utilizas el createBaffle para crear el parche interno a la malla. podrias tu darme un ejemplo que hallas realizado para poder revisarlo por favor ?
saludos
Curico is offline   Reply With Quote
Old   November 10, 2011, 08:22
Cesar Retamal Bravo
Hi Sylvian,
I would like to know how to use to create the patch createBaffle internal to the mesh. could you give me an example to review Hall on please?
regards
Old   November 15, 2011, 03:06
Sylvain Aguinaga
Hola Curico
Voy a escribir en ingles porque es mas facil para mi Mi espanol es un poquito viejo
to create an internal baffle, the trick is to define empty patches in blockMesh, so:
1) you add those lines in BlockMeshDict
    fan_amont
        type cyclic;
        faces ();
        neighbourPatch fan_aval;
    fan_aval
        type cyclic;
        faces ();
        neighbourPatch fan_amont;
Then you go on with your meshing procedure as usual. if you mesh with an another software than openFoam, your add those empty patches in the constant/polyMesh/boundary file
2) you have then to "mark" the faces which will form your baffles. You have to use the TopoSet tool. The easier way to use it according to me is to use a TopoSetDict file placed in the system folder. Here is an example of my toposetdict file
|  \\    /   O peration     | Version:  2.0.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
        name    cyclicfanFaces;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
            box (-1.52 -11 -1)(-1.47 -6.5 3);//bien réglé à la frontiere de deux faces verticales
        name    cyclicfanFacesSlaveCells;
        type    cellSet;
        action  new;
        source  boxToCell;
        sourceInfo
            box (-1.5 -11 -1)(6 -6.5 3);
        name    cyclicfanZoneFaces;
        type    faceZoneSet;
        action  new;
        source  setsToFaceZone;
        sourceInfo
            faceSet cyclicfanFaces;
            cellSet cyclicfanFacesSlaveCells;
The first piece of code select the set of faces of the baffle, the second a select a set of cells upstream your baffle. this set of baffles actually define the direction of your fan!! The third combine the two first pieces into a face zone
3) the last part is to use your brand new facezone to actually create the baffle
here is the command line for my example
createBaffles cyclicfanZoneFaces '(fan_amont fan_aval)' -internalFacesOnly
Now if you run parafoam you should see your baffle.
According to me, the most tricky part is to select the cells with toposet, especially if you mesh with snappy, is quite difficult to setup the appropriate box which select only the faces in the baffle
Hope it will be usefull, keep me in touch
Sylvain
Old   December 10, 2012, 13:18
Jamal
aujamal20 is an unknown quantity at this point
Dear
I am using topoSetDict to creat fluid and solid regions and facing problems. BlockMesh work properly and give the mesh while topoSet run with no error but causing no affect.
BlockMeshDict
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0.01)
(0.5 0 0.01)
( 0.5 0 -0.01)
(0 0 -0.01)
(0 1 0.01)
(0.5 1 0.01)
(0.5 1 -0.01)
(0 1 -0.01)
blocks
hex (0 1 2 3 4 5 6 7) (50 3 100) simpleGrading (1 1 1)
edges
boundary
minX
type patch;
faces
(0 4 7 3)
maxX
type wall;
faces
(2 6 5 1)
minY
type wall;
faces
(0 3 2 1)
maxY
type wall;
faces
(4 5 6 7)
// frontAndBack
// type empty;
// faces
// (1 5 4 0)
// (3 7 6 2)
front
type wall;
faces
(0 1 5 4)
back
type wall;
faces
(3 7 6 2)
mergePatchPairs
and topoSetDict is
FoamFile
version 2.0;
format ascii;
class dictionary;
object topoSetDict;
actions
// solid
name Solid;
type cellSet;
action new;
source boxToCell;
sourceInfo
box (0 0 0.01)(0.5 0.1 -0.01);
name Solid;
type cellSet;
action add;
source boxToCell;
sourceInfo
box (0.4 0.1 0.01)(0.5 0.9 -0.01);
name Solid;
type cellSet;
action add;
source boxToCell;
sourceInfo
box (0 0.9 0.01)(0.5 1 -0.01);
name Solid;
type cellSet;
action add;
source boxToCell;
sourceInfo
box (0 0.1 0.01)(0.1 0.9 -0.01);
name Solid;
type cellSet;
action add;
source boxToCell;
sourceInfo
box (0 0.3 0.01)(0.1 0.7 -0.01);
name Solid;
type cellSet;
action add;
source boxToCell;
sourceInfo
box (0 0.8 0.01)(0.1 0.9 -0.01);
name Solid;
type cellZoneSet;
action new;
source setToCellZone;
sourceInfo
set Solid; // name of cellSet
// fluid
name Fluid;
type cellSet;
action new;
source boxToCell;
sourceInfo
box (0.1 0.1 0.01)(0.4 0.9 -0.01);
name Fluid;
type cellSet;
action add;
source boxToCell;
sourceInfo
box (0 0.2 0.01)(0.1 0.3 -0.01);
name Fluid;
type cellSet;
action add;
source boxToCell;
sourceInfo
box (0 0.7 0.01)(0.1 0.8 -0.01);
name Fluid;
type cellZoneSet;
action new;
sourceInfo
set Fluid;
is there any special arrangment for adding box to give same region properties.
Regards
Jamal
aujamal20 is offline   Reply With Quote
Old   September 11, 2014, 06:01
coroi is on a distinguished road
fan_uptream
type fanPressure;
gamma 1;
fan_downstream
type fanPressure;
gamma 1;
Cheers
Sylvain
Hi everyone,
Can somebody tell me please if in order to setup the fanPressure BC it is compulsory to create two patches (fanInlet and fanOutlet) or just one is sufficient? If 2 patches are compulsory could one of them be inside the computatinal domain and the other one at the boundary?
Thank you in advance for your help!
coroi is offline   Reply With Quote
Old   October 14, 2016, 06:06
Default Problem with outflow in fanPressure
  #16
xsa
Xabi
xsa is on a distinguished road
I have to simulate with OpenFOam 3.0.x an electric motor which is cooled with the help of a fan and I am using the solver "chtMultiRegionFoam" for the heat exchange. I am with the heatExchanger tutorial and i have done the simulation with a fixed pressure and i had no problems, but I am having problems when I insert the fanPressure BC with the airflow. I have tried with the "angleDuct" tutorial also and i had the same problems.
So for the setting of the pressure (omitting the other boundaries), the inlet value would be the one from the fanCurve, and the setting i have is this:
inlet
type fanPressure;
fileName "./constant/air/fanCurve_148";
outOfBounds clamp;
direction out;
p0 uniform 100000; //atmospheric pressure
value uniform 100000;
gamma 1;
outlet
type inletOutlet;
inletalue uniform 100000;
The fanCurve is written like this:
5
(0.05 4400) // (flow[m^3/s] pressure_jump[Pa])
(0.07 4300)
(0.08 4250)
(0.09 4150)
(0.10 4100)
And the velocity is written like this:
inlet
outlet
type inletOutlet;
After running the solver, i get the next error:
request for volScalarField none from objectRegistry air failed available objects of type volScalarField are
17
interRegionHeatTransferModel:htc
thermo:mu
thermosi
nut
h
My guess is that problem is when reading the velocity from the fanCurve as the airflow is defined in m^3/s, whereas the velocity is defined in m/s and as a vector.
So does somebody know how to fix this and be able to read the airflow in m^3/s with the fanCurve?
xsa is offline   Reply With Quote
Old   January 19, 2017, 17:46
M. C.
student666 is on a distinguished road
Hi xsa,
have you succed to run your case? Can you post the BCs you set?
I'm interested to understand how fanPressureWorks.
thanks
student666 is offline   Reply With Quote
Old   January 20, 2017, 01:48
xsa
Xabi
Hi Student666,
i saw your other thread and i was going to ask you the same question.
The only thing i have managed so far is that the simulation starts "running" by setting the BC of the velocity inlet to zeroGradient, because with other BC i got error messages.
0/U
inlet
     type     zeroGradient;
0/p
inlet
     type                fanPressure;
     fileName           "fanCurve";
     outOfBounds         clamp;
     direction           in;
     U                   U;
     phi                 phi;
     p0                  uniform 0;
     value               uniform 0;
     gamma               1;
But i am using the solver chtMultiRegionSimpleFoam for the case i need, and in the first second i already get unrealistic temperature values.
Sorry for not being able to help you for now, if i get it to work i will post it here. Please let us know if you make it work.
Good luck
Xsa
Old   January 20, 2017, 07:18
M. C.
Hi Xsa,
thanks for your reply.
By your setting I supposed your case involved a fan that is blowing air inside the domain; you blow air against your motor in order to cool it down. If that's your set up, it is different from mine, as "my fan" aspire air from the domain.
Have a look to this paper
https://www.google.it/url?sa=t&rct=j...44224172,d.d24
I think you can get a helping hand if you look to the end, where the author wrote his bcs...
I'm still working on it...keep us in touch.
Regards
s1291 likes this.
Old   January 23, 2017, 04:23
xsa
Xabi
Hi student666,
First, thanks for the paper! i have given a quick glance and it seems it is going to be of a lot of help for my case setup!!
And your guess is true, in my case i blow air through the motor to cool it down, so it is a bit different from your case...
I will study the paper thoroughly and hopefully i am able to solve my problems. Hope you find the solution soon, keep it up!
Regards
