boundary conditions- new case problem
Old   August 23, 2011, 04:24
Default boundary conditions- new case problem
Sebastian
Sebaj is on a distinguished road
Welcome everyone I have problem with new case..
When I translate mesh from icem I received mesh with 8 boundaries. then I try do standard simulation by solver icoFoam, but then I gets error :
--> FOAM FATAL IO ERROR:
keyword PIPE_EDGE_0 is undefined in dictionary "/mnt/auto/people/plgsebaa/test_case/pipe_test1/0/p::boundaryField"
file: /mnt/auto/people/plgsebaa/test_case/pipe_test1/0/p::boundaryField from line 25 to line 53.
From function dictionary::subDict(const word& keyword) const
in file db/dictionary/dictionary.C at line 456.
FOAM exiting
but in file p i defined Pipe egde..
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
IN_OUT_0
type zeroGradient;
IN_OUT_1
type zeroGradient;
IN_OUT_2
type zeroGradient;
BODY_HOT
type zeroGradient;
BODY_COLD
type zeroGradient;
PIPE_EGDE_0
type empty;
PIPE_EGDE_1
type empty;
PIPE_EGDE_2
type empty;
here in_out it's holes
body hot it's internal mesh
body cold it's external mesh
and pipe edge it's surface at the hole
any Ideas how to do?
greet Seba
Sebaj is offline   Reply With Quote
Old   August 23, 2011, 04:31
Steven van Haren
stevenvanharen is on a distinguished road
i think your spelling is incorrect, you seem to have EDGE and EGDE
stevenvanharen is offline   Reply With Quote
Old   August 23, 2011, 04:45
Sebastian
of course you're right..
now another error.. may be badly defined ??
patch type 'wall' not constraint type 'empty'
for patch PIPE_EDGE_0 of field p in file "/mnt/auto/people/plgsebaa/test_case/pipe_test1/0/p"
file: /mnt/auto/people/plgsebaa/test_case/pipe_test1/0/p::boundaryField::PIPE_EDGE_0 from line 45 to line 45.
From function emptyFvPatchField<Type>::emptyFvPatchField
const fvPatch& p,
const Field<Type>& field,
const dictionary& dict
in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 100.
FOAM exiting
Old   August 23, 2011, 04:55
Steven van Haren
check you boundary definition in constant/polyMesh/boundary
Do you also have patches specified as empty there?
Old   August 23, 2011, 05:01
Sebastian
there I have:
boundary
IN_OUT_0
type wall;
nFaces 7136;
startFace 8976957;
IN_OUT_1
type wall;
nFaces 7286;
startFace 8984093;
IN_OUT_2
type wall;
nFaces 6887;
startFace 8991379;
BODY_COLD
type wall;
nFaces 65467;
startFace 8998266;
BODY_HOT
type wall;
nFaces 123362;
startFace 9063733;
PIPE_EDGE_0
type wall;
nFaces 12612;
startFace 9187095;
PIPE_EDGE_1
type wall;
nFaces 12705;
startFace 9199707;
PIPE_EDGE_2
type wall;
nFaces 12135;
startFace 9212412;
Old   August 23, 2011, 05:08
Steven van Haren
you should have type empty in your constant/polyMesh/boundary file for your empty patches
take a look at the cavity tutorial:
$FOAM_TUTORIALS/incompressible/icoFoam/cavity/
Old   August 23, 2011, 05:23
Sebastian
next problem..
You're right also and file U i also must edit. now it almost works but
Starting time loop
Time = 0.005
Courant Number mean: 0 max: 0.0551093
--> FOAM FATAL ERROR:
This mesh contains patches of type empty but is not 1D or 2D
by virtue of the fact that the number of faces of this
empty patch is not divisible by the number of cells.
From function emptyFvPatchField<Type>::updateCoeffs()
in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 150.
FOAM exiting
is that because time step (deltaT = 0.005) is to big?
Old   August 23, 2011, 05:41
Steven van Haren
no, sorry, did not look at your mesh before, empty patches are only used for 2D or 1D problems
Why do you want to use empty patches? Where are you PIPE_EDGES exactly in your mesh? Are they not just walls?
Old   August 23, 2011, 05:55
Sebastian
pipe_edge is wall and it should be fixedValue I suppose. but then when flow influence in pipe by entry.. I got new error:
Time = 0.005
DILUPBiCG: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 5.26457e-07, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 36.481
Specified mass inflow : 7539.44
Specified mass outflow : 0
Adjustable mass outflow : 0
From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p
in file cfdTools/general/adjustPhi/adjustPhi.C at line 115.
FOAM exiting
and then I try do "exit" from pipe by change wall into empty space
Old   August 23, 2011, 07:24
Steven van Haren
OpenFOAM normally gives nice errors. In this case it tells you to use potentialFoam to initialize the flow, did you try this?
Old   August 24, 2011, 05:34
Sebastian
now, I change files little bit and something is running.. I will see is that correct
greets Seba
Old   August 24, 2011, 05:58
A.D.E is on a distinguished road
Hi stevenvanharen
I saw how helpful you were with Sebaj and I was wondering if you can help me as well. I am running a 2d case in OpenFoam using simpleFoam (incompressible 60m/s) and it gives me this error.
DILUPBiCG: Solving for Ux, Initial residual = 0.324483, Final residual = 6.30403e-06, No Iterations 5
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
in "/opt/openfoam200/platforms/linuxGccDPOpt/bin/simpleFoam"
#7 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Do you have any idea y?
Thank you in advance for your time,
Sincerely,
A.D.E
A.D.E is offline   Reply With Quote
Old   August 24, 2011, 06:52
Sebastian
me again..
probably i have similiar problem..
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 0.05
Courant Number mean: 0 max: 0.551093
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 4.69515e-08, No Iterations 2
DICPCG: Solving for p, Initial residual = 1, Final residual = 9.60954e-07, No Iterations 609
time step continuity errors : sum local = 4.2065e-11, global = -1.63323e-14, cumulative = -1.63323e-14
DICPCG: Solving for p, Initial residual = 0.208382, Final residual = 9.50018e-07, No Iterations 506
time step continuity errors : sum local = 2.39418e-08, global = 5.87107e-12, cumulative = 5.85473e-12
ExecutionTime = 270.09 s ClockTime = 270 s
Time = 0.1
Courant Number mean: 0.00498182 max: 0.880283
DILUPBiCG: Solving for Ux, Initial residual = 0.31478, Final residual = 5.87127e-07, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.379635, Final residual = 1.43089e-07, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.333154, Final residual = 2.7084e-06, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.0603557, Final residual = 9.74963e-07, No Iterations 538
time step continuity errors : sum local = 3.10184e-08, global = -4.42633e-11, cumulative = -3.84085e-11
DICPCG: Solving for p, Initial residual = 0.68873, Final residual = 9.67525e-07, No Iterations 522
time step continuity errors : sum local = 7.39548e-09, global = 1.9175e-11, cumulative = -1.92335e-11
ExecutionTime = 516.3 s ClockTime = 516 s
Time = 0.15
Courant Number mean: 0.00533215 max: 1.34034
DILUPBiCG: Solving for Ux, Initial residual = 0.0226568, Final residual = 2.8223e-06, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.0133874, Final residual = 5.66317e-06, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.116657, Final residual = 3.36112e-07, No Iterations 3
DICPCG: Solving for p, Initial residual = 0.5099, Final residual = 9.89826e-07, No Iterations 530
time step continuity errors : sum local = 2.90012e-09, global = 1.72753e-12, cumulative = -1.7506e-11
DICPCG: Solving for p, Initial residual = 0.216951, Final residual = 9.63454e-07, No Iterations 503
time step continuity errors : sum local = 1.80248e-09, global = -1.18666e-11, cumulative = -2.93726e-11
ExecutionTime = 778.59 s ClockTime = 778 s
Time = 0.2
Courant Number mean: 0.00529183 max: 3.17097
DILUPBiCG: Solving for Ux, Initial residual = 0.012159, Final residual = 7.18277e-06, No Iterations 9
DILUPBiCG: Solving for Uy, Initial residual = 0.00836557, Final residual = 6.1792e-06, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 0.0491227, Final residual = 2.08374e-06, No Iterations 8
DICPCG: Solving for p, Initial residual = 0.287848, Final residual = 9.7348e-07, No Iterations 552
time step continuity errors : sum local = 1.46002e-09, global = 6.9727e-13, cumulative = -2.86753e-11
DICPCG: Solving for p, Initial residual = 0.121064, Final residual = 8.8766e-07, No Iterations 557
time step continuity errors : sum local = 1.05088e-09, global = -1.58428e-12, cumulative = -3.02596e-11
ExecutionTime = 1066.14 s ClockTime = 1066 s
End
and it's not write time files..
what's wrong?
greets Seba
Old   August 24, 2011, 07:06
Florian Krause
florian_krause is on a distinguished road
Hello Seba,
data writing is specified in the controlDict, see http://www.openfoam.com/docs/user/controlDict.php
Hope this helps.
Florian
florian_krause is offline   Reply With Quote
Old   August 24, 2011, 07:13
Steven van Haren
Originally Posted by A.D.E View Post
Hi stevenvanharen
#2 Uninterpreted:
Sincerely,
A.D.E
I don't really know what generates this error. It seems to be originating from the matrix solver, maybe you can try a different matrix solver, see what happens?
Old   August 24, 2011, 07:36
Sebastian
hi florian_krause
my controlDict file, here I think everything is ok
problem is maybe in other file?
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application icoFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 0.2;
deltaT 0.05;
writeControl timeStep;
writeInterval 20;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
Old   August 24, 2011, 07:52
Florian Krause
Hello Seba,
you specify:
deltaT 0.05;
writeInterval 20;
you write out your fields every 20 time steps, but you have only 4 time steps of deltaT=0.05 to reach endTime 0.2.
Should be clear now.
Florian
Old   August 24, 2011, 08:52
Sebastian
hey florian_krause,
when I change writeInterval 20; to 1 how You advised, it's work
thanks a lot
now i try to visualize data
Old   August 18, 2016, 06:57
Unhappy
  #19
srikanth
sri9017 is on a distinguished road
greets Seba
Hi Seba,
I m getting the same error as your yours could you tell me how you corrected it ??
The error is
Starting time loop
Time = 0.0005
Courant Number mean: 0.000416667 max: 0.0416667
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 8.31588e-07, No Iterations 3
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.21225e-06, No Iterations 3
Total flux : 2.89283e-05
Specified mass inflow : 0.0005
From function adjustPhi(surfaceScalarField&, const volVectorField&,volScalarField&)
in file cfdTools/general/adjustPhi/adjustPhi.C at line 118.
FOAM exiting
Thanks in advance
sri9017 is offline   Reply With Quote
Old   August 23, 2016, 04:57
Sebastian
Try adding special small surface (inletoutlet without airflow velocity set) to compensate fot inequality between inflow and outflow
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
Fluent boundary conditions problem bobo FLUENT 2 July 3, 2009 06:28
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 08:59
Book Jan Ramboer Main CFD Forum 5 August 9, 1999 02:01
