yPlus for LowRe-turbulence models
Like Tree1Likes
  • 1 Post By FelixL
Old   September 10, 2011, 04:50
Default yPlus for LowRe-turbulence models
André Laß
cabul is on a distinguished road
Hello FOAMers,
I am quite new to OpenFOAM and i want to use a LowRe-turbulence model without Wallmodelling like the LamBremhorstKE model for an impinging jet simulation.
Is there a way to calculate the yPlus-values to ensure that y+ is below 1 at every wall?
The utility yPlusRAS seems only to work with nutWallfunction in use.
I would be Grad if anyone could live a hint...
cabul is offline   Reply With Quote
Old   September 10, 2011, 05:07
Felix L.
FelixL is on a distinguished road
Good morning, Andre,
you can estimate a cell height using a prescribed y+ with this tool:
http://geolab.larc.nasa.gov/APPS/YPlus/
On the other side, if you have experimental reference data available you can check it for measured wall shear stresses or even friction velocities to use for your estimation.
Greetings,
Felix.
FelixL is offline   Reply With Quote
Old   September 10, 2011, 05:18
André Laß
Hello Felix,
Thanks for you hint according the estimation.
Do you know a way to compute the yPlus value at all near-wall nodes? Because I'd like to plot the yPlus value along the entire Wall using paraview.
Greetings,
André
Old   September 10, 2011, 06:16
Felix L.
I suggest searching the forums for this, there are plenty of threads dealing with this topic.
You probably have to use the nutLowReWallFunction for nut at the wall patch and run yPlusRAS afterwards.
Greetings,
Felix.
Old   September 10, 2011, 07:06
André Laß
[So you would say that the nutLowReWallfunction does not affect the solution when y+ is below 1? When using this wallfunction Do i have to use wallfunctions for k and epsilon too or can i set them to zero as default in lowRe-turbulence model?
Thanks for you help
Old   September 10, 2011, 07:22
Felix L.
The nutLowReWallfunction is only a dummy wall function which effectively sets the eddy viscosity to zero at the wall (which is true for y+<5). The BCs for k and epsilon can be chosen independently and shouldn't be wall functions.
Greetings,
Felix.
fumiya likes this.
Old   September 10, 2011, 09:43
Smile
André Laß
Thank you every much for your help...
Incompressible Turbulence models achinta OpenFOAM 4 May 27, 2010 10:35
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 15:39
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 04:34
