[snappyHexMesh] Mesh quality when using snappyHexMesh
Old   September 20, 2011, 10:50
Default Mesh quality when using snappyHexMesh
Johan
newToOpenFoam is on a distinguished road
When I examined the mesh produced in the motorBike tutorial (using paraView) I was surprised to see irregularities of highly distorted cells.
Aren't those expected to reduce the accuracy of the calculations and if that is the case, is it possible to avoid production of such cells?
newToOpenFoam is offline   Reply With Quote
Old   September 28, 2011, 22:25
Lee Yin Jen
YJ Lee is on a distinguished road
Wonder if my reply is a little late. I'm a new OpenFOAM user and have been poking around some functionalities, fascinated by snappyHexMesh and is trying to learn. Having the same situation when I used sHM to mesh an aircraft geometry for external aerodynamics - lots of "messy" cells viewed in Paraview. However, some other threads seem to indicate that the 'apparent' poor quality is due to Paraview's inability to handle polyhedral mesh - and the viewer will attempt to interpret every cell as tet or hex. Hence some apparently poor cells may be produced.
Cheers!
Edit: You may want to check out this thread: http://www.cfd-online.com/Forums/ope...ated-mesh.html
Last edited by YJ Lee; September 28, 2011 at 22:40. Reason: Add a link to related thread
YJ Lee is offline   Reply With Quote
mesh evaluting, mesh generation, snappyhexmesh
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[OpenFOAM] snappyHexMesh - can't open mesh in ParaView tfigueiro ParaView 0 June 11, 2015 19:05
[snappyHexMesh] Mesh quality control in snappyHexMesh - OpenFOAM 2.3.0 arapuraz OpenFOAM Meshing & Mesh Conversion 1 August 12, 2014 04:17
