open channel flow with open foam
Old   September 24, 2011, 22:53
Default open channel flow with open foam
robert sirasch
windyday is on a distinguished road
I would like some assistance with creating an open foam open channel model.
Can anyone point me to examples.
Its just a very simple model that i need to start with and I have no experience with open foam.
Perhaps there is a easier program to use?
regards and thanks
windyday is offline   Reply With Quote
Old   September 26, 2011, 07:22
Matthew Denno
mgdenno is on a distinguished road
I would suggest starting with the dam break tutorial. Once you understand that I would change the boundary conditions to create an inlet and outlet. It will be 2D at this point, then you can work toward making it 3D.
mgdenno is offline   Reply With Quote
Old   September 26, 2011, 10:13
robert sirasch
Thank you for your suggestion.
Will this model handle a hydraulic jump by a feature on the floor of the channel?
in 3d?
Old   September 26, 2011, 10:23
Matthew Denno
Yes it will. I have been using it to model spillways and energy dissipation structures, and it seems to capture the hydraulic jumps in the stilling basins well. I think if you Google "spillway openfoam" you will find a few youtube videos showing a hydraulic jump...they are not mine, but I recall seeing them.
Old   September 26, 2011, 17:04
Default open channel flow simulation
robert sirasch
ok, thanks that sounds good.
have you had anything to do with FANS?
(Finite-Analytic Navier-Stokes (FANS))
if so which do you think is the easier and more effective to use?
open channel flow
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 07:20
Open Channel Flow ElanMorin FLUENT 4 February 25, 2015 16:26
Open Channel Flow OffshoreStructuralEnginer CFX 13 August 3, 2010 21:31
Open Channel Flow forsumit FLUENT 0 October 1, 2009 02:01
Open Channel flow Boundary khalid FLUENT 1 November 4, 2006 11:53
