Simulation of bubble plumes
Old   November 11, 2010, 07:07
Default Simulation of bubble plumes
Jolyn Chuah
jolync is on a distinguished road
Hi all,
May I know if anyone has done simulation for bubble plume using OpenFOAM before? Could you kindly share the file for guidance as I'm totally new to OpenFOAM..
Questions:
How to set the boundary and initial conditions?
Which solver should we use in specific?
Thank you!
jolync is offline   Reply With Quote
Old   November 11, 2010, 07:46
FG_HSRM is on a distinguished road
Hello Jolync,
a good starting point are the user's and programmer's guide, there you will surely learn to handle your first problems.
OF includes a whole bunch of tutorials, also multiphase flow solvers; interFoam, interDyMFoam, and bubbleFoam (one of this, might be useful for you).
Rergards
fritz
FG_HSRM is offline   Reply With Quote
Old   November 11, 2010, 07:54
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Are you looking to model the dispersed phase in an Eulerian or Lagrangian way?
People have published work on gas-liquid bubble columns using OpenFOAM. Do a quick google search.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   November 11, 2010, 08:15
Jolyn Chuah
Hi Freidrich,
Yup, I've gone through the user guide. But I still don't know how to make use of the multiphase - twophaseEuler solver to get started with the simulation. Hence, the post for help.
Thank you
Old   November 11, 2010, 08:20
Jolyn Chuah
Hi Laurence,
I think its the Eulerian method. I tried looking, but haven't found materials that are really helpful. Shall look into it again.
Thanks!
Old   November 11, 2010, 08:33
Sorry, I'm not being helpful:
Selma
Silva
Those should get you rolling on the implementation side. And of course don't forget Henrik Rusche's thesis.
I'm not used to the solver, but what exactly is your problem?
Just jump into the twoPhaseEulerFoam/ bubbleColumn directory, create the Mesh with "blockMesh" and start the solver with "twoPhaseEulerFoam".
After finishing the tutorial, keep on and change the things to your needs.
Old   September 28, 2011, 09:55
Aurelien Thinat
Aurelien Thinat is on a distinguished road
I'm trying to run a case closed to the test case Bubble Plume presented in Henrik Rusche's thesis.
Different by the injection way of bubbles in the domain : I have created a source term (a volumic scalar) in the alpha equation of bubbleFoam solver. Not a big deal normally (well, it's more a guess than something serious).
It's a 2D case, the flow is considered as laminar for a start. The sides are walls (or symmetryPlane), the bottom is a wall too and the upper boundary is an inletOutlet.
So at t=0, I put alpha = 0 if z<0,14 and alpha = 1 if z>0,14. And then some bubbles are created by the source term along the left wall.
So my main problems are :
- The interface has a strange behaviour which depends on the diameters da and db.
- If db is too high, (close to 1mm), the calculation is very unstable.
- At very small db, I have a loss of "water" (continuous phase). I guess it's something like a numerical "evaporation".
Anybody already faced these problems ?
Thank you.
Aurelien Thinat is offline   Reply With Quote
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Help required for CFD simulation of Trayed Bubble Column using Fluent art705 Main CFD Forum 0 July 15, 2009 04:04
Enquiry about the flame simulation in rotary kiln hassanelattar FLUENT 0 March 25, 2009 07:41
Air Bubble simulation Raj CFX 1 October 6, 2008 22:53
phase filed simulation of a bubble qunwuhe@hotmail.com Main CFD Forum 0 June 5, 2007 22:56
