October 4, 2011, 05:07 |
Probes
supercommandodhruv
Rep Power: 14 |
Hello All,
I am using probes function to have data points at some locations in my domain. I have 2 questions. 1. If I use U as fields, I get the three components at of velocity at that point. Is there a way to get the magnitude of velocity at that point (like mag U) ? 2. For the location of the probes, I have different locations which changes with every test case, so I want the controlDict to read the locations from from a different file, where I have set the formula for the location points. How can I do this? Thanks in advance for your help. Dhruv. |
October 4, 2011, 11:46 |
Nicolas Edh
Rep Power: 18 |
I'm not sure about the first question, maybe someone else can help you there. For the second question; you can use include statements in your controlDict file, Code:
... probeLocations ( #include "some/PATH/someFile" ); ... Good Luck /N |
October 5, 2011, 02:55 |
Thanks
#3 | |
supercommandodhruv
Rep Power: 14 |
Thanks nsf,
I also looked in one of the tutorials, and found the same. I will try it today. Dhruv. Quote:
October 5, 2011, 12:59 |
#4 | |
Nicolas Edh
Rep Power: 18 |
Here's a trick I'd like to share for those new to linux and bash. Let's say you wanted to find tutorial examples that use include statements in the controlDict file, this one-liner can help you Code:
find $FOAM_TUTORIALS -name controlDict | xargs grep "#include" Hopefully someone will find this useful . /Nicolas |
probes |
Error using probes | balkrishna | OpenFOAM Running, Solving & CFD | 6 | November 12, 2010 04:55 |
Resolving Velocity Magnitudes with Probes | steph79 | OpenFOAM | 2 | August 9, 2010 18:16 |
probes for a component of a volTensorField | titio | OpenFOAM Post-Processing | 0 | July 2, 2010 13:50 |
problems with probes() function in chtMultiRegionFoam | Victor | OpenFOAM | 0 | November 25, 2009 15:08 |
Probes and multiprocessor runs | grtabor | OpenFOAM Running, Solving & CFD | 1 | June 12, 2007 13:59 |
