symbol lookup error:
Old   October 5, 2011, 04:02
Default symbol lookup error:
Thor Ugelvig Petersen
tupe is on a distinguished road
I get following error message when i try to run a turbulence model in OpenFOAM 1.6-ext:
pimpleWaveCurrentDyMFoam: symbol lookup error: /xbar/nas2/home1/s04/tupe/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libincompressibleRASModels.so: undefined symbol: _ZN4Foam14incompressible8RASModel11printCoeffsEv
How to correct this error?
tupe is offline   Reply With Quote
Old   October 5, 2011, 16:58
Adhiraj
adhiraj is on a distinguished road
This means you need to include the required library. For instance if solver0
depends on library0, and there are functions declared in library0 which are defined in library1, you need to specify both libraries for linking with your solver, and in the proper order.
Hope that helps.
adhiraj is offline   Reply With Quote
Old   October 6, 2011, 09:30
thank you. I was writing over the original library in OpenFOAM when compiling my own solver. So you were right, I had to change the destination of the library.
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 06:12
user defined function cfduser CFX 0 April 29, 2006 10:58
