hPolynomialThermo and janafThermo in Interfoam |
January 24, 2011, 13:31 |
karthik
Rep Power: 15 |
hey all,
can hPolynomialThermo and janafThermo be used with interfoam?? please give me advice about this, as i am very new to the openFoam software... thank you. best regards, Karthik |
January 25, 2011, 01:24 |
Nakul
Rep Power: 16 |
Hi
Check in the source code of the thermophysical model being used in interFoam if any combination of hpolynomialthermo anf JANAF thermo is available as a valid combination. |
February 8, 2011, 12:38 |
#3 | |
karthik
Rep Power: 15 |
thank you very much for the advice, i tried comparing and couldnt figure out anything... other than hpolynomialthermo and janafthermo, any idea how to vary Cp value and density with pressure and temperature, in a 2 phase vof problem? thanks again Karthik |
February 10, 2011, 00:58 |
Nakul
Rep Power: 16 |
I don't know how you intend to calculate Cp and I also can't be of much help as I don't know multiphase flows.
However you can search around or maybe even code yourself - the way you want to calculate cp. Search the forum and you may find some useful threads. |
November 24, 2011, 11:23 |
Olivier
Rep Power: 17 |
hello Karthik,
where you able to get interFoam work with other thermotype than incompressible newtonian ? I am looking for a 2 phase, one ideal gaz, the other hPolynomial, but didn"t find any info about such solver. regards, olivier |
hpolynomialthermo, interfoam, janafthermo |
janafThermo: How to read formula? or at least: How to use hPolynomialThermo? | bgoeppner | OpenFOAM | 0 | February 22, 2010 15:17 |
