gmshToFoam teminates on Segmentation fault
Old   November 29, 2011, 08:33
Default gmshToFoam teminates on Segmentation fault
XXLRay is on a distinguished road
I created a .msh file with gmsh 2.4.2 on Ubuntu Linux. Now I want to convert it to OpenFoam201. I copied the mesh to the OpenFoam example folder $FOAM_RUN/tutorials/incompressible/icoFoam/cavity/ . There I executed "gmshToFoam ./Savonius_S2.geo.msh". It terminates on a Segmentation fault (I shortened some long output):
|  \\    /   O peration     | Version:  2.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : 2.0.1-51f1de99a4bc
Exec   : gmshToFoam ./Savonius_S2.geo.msh
Date   : Nov 29 2011
Host   : ubuntu
PID    : 8927
Case   : /home/hanke/OpenFOAM/hanke-2.0.1/run/tutorials/incompressible/icoFoam/Savonius
nProcs : 1
Create time
Starting to read mesh format at line 2
Read format version 2.1  ascii 0
Starting to read points at line 5
Vertices to be read:175
Vertices read:175
Starting to read cells at line 183
Cells to be read:1333
Unhandled element 15 at line 185
Unhandled element 15 at line 209
Unhandled element 1 at line 210
Unhandled element 1 at line 305
Mapping region 0 to Foam patch 0
Mapping region 0 to Foam cellZone 0
Cells:
    total:876
    hex  :0
    prism:0
    pyr  :0
    tet  :876
CellZones:
Zone    Size
    0    876
Skipping tag  at line 1519
Patch 0 gets name patch0
Finding faces of patch 0
--> FOAM Warning : Not using gmsh face 3(27 25 7) since zero vertex is not on boundary of polyMesh
--> FOAM Warning : Not using gmsh face 3(22 35 38) since zero vertex is not on boundary of polyMesh
FaceZones:
Zone    Size
    0    336
Writing zone 0 to cellZone cellZone_0 and cellSet
Writing zone 0 to faceZone faceZone_0 and faceSet
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigSegv::sigHandler(int) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2  Uninterpreted:
 in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/gmshToFoam"
#4  __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Segmentation fault
I guess that something is wrong with my mesh. I attached the file and would be glad if you could have a look at it.
XXLRay is offline   Reply With Quote
Old   November 30, 2011, 02:50
-mAx-'s Avatar
Maxime Perelli
you are not in the right forum >>>> http://www.cfd-online.com/Forums/ope...meshing-other/
With which software did you create your .msh file?
Old   November 30, 2011, 04:22
As stated out in the first post I created the mesh with gmsh 2.4.2.
Perhaps one of the admins could be so kind to move this thread to the correct location?
Old   December 2, 2011, 03:02
Can anybody confirm that the mesh itself and not my installation of OpenFOAM causes the fault?
Old   December 2, 2011, 03:47
In http://www.cfd-online.com/Forums/ope...ion-error.html a similar problem has been described. It seems as if it could be solved by removing the "gmsh label". Unfortunately I have not idea what this means. Anyone else?
Old   December 3, 2011, 04:25
I tried a mesh from an new smaller and simpler geometry (attached to this post). The output of the mesh conversion is now:
Exec   : gmshToFoam Cylinder.msh
Date   : Dec 03 2011
Time   : 10:07:35
Host   : ubuntu
PID    : 2222
Case   : /home/hanke/OpenFOAM/hanke-2.0.1/run/tutorials/incompressible/icoFoam/Cylinder
nProcs : 1
Create time
Vertices to be read:1232
Vertices read:1232
Starting to read cells at line 1240
Cells to be read:6835
Unhandled element 15 at line 1242
Unhandled element 1 at line 1367
Cells:
    total:5303
    hex  :0
    prism:0
    pyr  :0
    tet  :5303
CellZones:
Zone    Size
    0    5303
Skipping tag  at line 8078
--> FOAM Warning :
    From function polyMesh::polyMesh(... construct from shapes...)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 614
    Found 1406 undefined faces in mesh; adding to default patch.
FaceZones:
Zone    Size
End
Is this what I should expect?
Are the unhandled elements bad?
Does the conversion work now because the geometry is smaller or simpler (I used a copy of the incompressible/icofoam/cavity example as starting point)?
Which tutorial should I copy to convert the mesh from my initial Post?
When I directly launch "icoFoam" after conversion, I get the following error message:
Exec   : icoFoam
Date   : Dec 03 2011
Time   : 10:19:02
Host   : ubuntu
PID    : 2642
Case   : /home/.../run/tutorials/incompressible/icoFoam/Cylinder
nProcs : 1
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
--> FOAM FATAL IO ERROR:
keyword patch0 is undefined in dictionary "/home/.../run/tutorials/incompressible/icoFoam/Cylinder/0/p::boundaryField"
file: /home/.../run/tutorials/incompressible/icoFoam/Cylinder/0/p::boundaryField from line 25 to line 35.
    From function dictionary::subDict(const word& keyword) const
    in file db/dictionary/dictionary.C at line 461.
FOAM exiting
I get the same error message when I try to look at the mesh in paraFoam.
Is there something else I have to do before launching "icoFoam"?
Does the cavity tutorial simply not fit to my mesh?
Old   December 5, 2011, 03:21
Do you need any more information to help me? Just ask and I will provide it.
I expect it to be an effort of a few minutes for someone experienced to try my mesh. Finding a solution on my own yet took me weeks and will take me months. Any help is really appreciated.
Old   December 6, 2011, 03:45
Is anybody out there?
Old   December 6, 2011, 09:36
Retired Super Moderator
Bruno Santos
Greetings XXLRay,
I personally don't have time to test the mesh, but this should be self explanatory in one of your latter posts:
Basically your new mesh has patch names different from the patches defined in the original tutorial case. You'll need to see the file "constant/polyMesh/boundary" to see the list of patches your new mesh has, then edit all variable files in the folder "0".
I suggest that you review the first tutorial (or even all 3 tutorials) on the User Guide to remember about boundaries and patches: http://www.openfoam.com/docs/user/cavity.php#x5-40002.1
As for «removing the "gmsh label"», the ".gmsh" files can sometimes be in text format, so editing the mesh ".gmsh" file with a text editor might be the way to go!
Best regards and good luck!
Bruno
Old   December 7, 2011, 02:10
Thanks a lot. I will try that.
[OpenFOAM] Paraview - Segmentation fault grjmell ParaView 5 January 9, 2024 13:14
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 21:59
Segmentation Fault Shawn_A OpenFOAM Running, Solving & CFD 6 October 31, 2011 14:38
ParaView segmentation fault only for multiphase gwierink OpenFOAM 9 March 25, 2010 07:23
