dam break problem
Old   April 9, 2010, 22:58
Exclamation dam break issue
Tharek Mohtar
tharem is on a distinguished road
Hello.
I've been trying to validate the interFoam solver and i had some problems with the dam break tutorial. I noticed the following error:
The level of the free surface begins to fall before the fluid's wavefront reach the wall that is in contact with it.
I found some papers with experimental solutions of this case and the solutions given are quite different.
I've not made modifications on the tutorial, and if it is a demonstration of the openFOAM capacity i don't understand why this error.
If anybody else has noticed this please reply!
Thanks!
P.S: sorry for my English.
tharem is offline   Reply With Quote
Old   April 12, 2010, 04:27
Holger Marschall
holger_marschall is on a distinguished road
Send a message via Skype™ to holger_marschall
which reference do you refer to? The dambreak tutorial is based upon experiments by Koshizuka in 1995:
Koshizuka S, Tamako H, Oka Y. A particle method for incompressible viscous flow with fluid fragmentation.
Computational Fluid Mechanics Journal 1995; 113:134 –147.
For nice highspeed pictures have a look at
Deborah M. Greaves, Simulation of viscous water column collapse using adapting hierarchical grids.
Int. J. Numer. Meth. Fluids 2006; 50:693–711
Could you sketch the expected behavior and the one simulated in a illustrative drawing?
best,
Holger Marschall
web: http://www.holger-marschall.info
mail: holgermarschall@yahoo.de
holger_marschall is offline   Reply With Quote
Old   April 26, 2010, 19:19
Tharek Mohtar
Hi, Forgive me for not replying earlier. Well, my reference is the following:
By J. S. Wang, H. G. Ni, and Y. S. He. FINITE-DIFFERENCE TVD SCHEME FOR COMPUTATION OF DAM-BREAK PROBLEMS.
Journal of Hydraulic Engineering, Vol. 126, No. 4, April, 2000.
Here a figure extracted from the paper above named:
The level of the water column (10 meters) is not decreasing until the wavefront reaches the left side of the column, namely, the wall that is in contact with the column of fluid.
Old   April 26, 2010, 19:45
Tharek Mohtar
I can't upload the image because it exceeds the 97.7 KB.
Do you know what can i do?
forgive the inconvenience
Old   May 1, 2011, 16:12
Default About dam break
Atabak
atabak756 is on a distinguished road
Do somebody have dam break tutorial input mesh and data files.
I have seen the file with name of "dambreak.msh.gz" in tutorial however i can not find this input file in the web site.I appreciate if somebody send me mentioned file and Fluent case about it.
Thank you.
atabak756 is offline   Reply With Quote
Old   May 2, 2011, 13:22
Nima Samkhaniani
nimasam is on a distinguished road
hi friend
look at :
tutorials/multiphase/interFoam/laminar/damBreak
nimasam is offline   Reply With Quote
Old   May 2, 2011, 16:19
Atabak
hi,
Thanks for your answer.
I could not find this file.is it possible for you to give me these files directly?
Old   May 3, 2011, 02:36
Elvis
elvis will become famous soon enough
http://repo.or.cz/w/OpenFOAM-1.7.x.g...minar/damBreak
http://repo.or.cz/w/OpenFOAM-1.6.x.g...minar/damBreak
http://openfoam-extend.svn.sourcefor...inar/damBreak/
http://openfoam-extend.svn.sourcefor...Foam/damBreak/
elvis is offline   Reply With Quote
Old   May 3, 2011, 08:48
Atabak
Thank you for your answer.
I looked at the web site you sent me however i don't understand how can i use these sites because there is no Gambit file and Fluent case and data file.
i would appreciate if you send me the file that working in Gambit and fluent software.
Thanks again for your help
Old   May 3, 2011, 09:01
Nima Samkhaniani
hi friends
its blockMesh!
which is written for openFOAM use, however maybe this command, works for u
"foamToFluent"
Old   July 6, 2011, 16:19
Reynaldo_21's Avatar
Reynaldo
Reynaldo_21 is on a distinguished road
Originally Posted by nimasam View Post
hi friend
look at :
Hello. I am Mexican and I need this file dambreak.msh.gz could send it to me to my e-mail reynaldoag85@hotmai.com. Thank you for your help
Reynaldo_21 is offline   Reply With Quote
Old   December 14, 2011, 11:15
Default Any one worked with earthen dam break problem in ANSYS
  #12
yasharif
yasharif is on a distinguished road
Dear friends
Did any1 work with earthen dambreak problem in ANSYS fluent?
how to configure the earth part as solid or particle(because it is soil)?
Thnx in advance.
Sharif
yasharif is offline   Reply With Quote
break, dam, issue
interDyMFoam mass conservation issues - dam break tutorial kmooney OpenFOAM 5 June 1, 2010 14:23
Boundary Conditions in Gambit for a dam break model Lindsey FLUENT 2 October 5, 2009 02:53
[OpenFOAM] Tracking Volume Surface dam break problem sega ParaView 4 July 14, 2009 08:41
dam break problem sega Main CFD Forum 2 April 23, 2008 11:39
Dam break // wet bed Mehdi BEN ELHADJ Main CFD Forum 4 August 24, 2000 07:39
