solver crashed when it turns into backflow at outlet |
January 19, 2012, 05:01 |
#1 | |
Now I am simulating wall subcooled boiling in an upward vertical pipe in a two-fluid Euler-Euler model. Due to the undevelopped velocity/temperature profile at the beginning, a large oscillation of pressure occurs. (Evaporation at the wall introduces a large pressure and condensation in the cold liquid core brings a small one) And finally there could be some backflow at outlet sometime. When the backflow occurs, every transport eqn could be solved except the standard k-epsilon eqn. The solver crashed when it's trying to solver epsilon and gave a message: Quote:
dimensions [0 2 -3 0 0 0 0]; internalField uniform 0.079; boundaryField { inlet { type fixedValue; value uniform 0.079; } outlet { type inletOutlet; inletValue uniform 0.079; value uniform 0.079; } walls { type zeroGradient; } defaultFaces { type empty; } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.0059; boundaryField { inlet { type fixedValue; value uniform 0.0059; } outlet { type inletOutlet; inletValue uniform 0.0059; value uniform 0.0059; } walls { type zeroGradient; } } Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 14.59e5; boundaryField { inlet { type buoyantPressure; value uniform 14.59e5; } outlet { type fixedValue; value uniform 14.59e5; } walls { type zeroGradient; } } Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 1.72256); boundaryField { inlet { type fixedValue; value uniform (0 0 1.72256); } outlet { type pressureInletOutletVelocity; value uniform (0 0 0); } walls { type fixedValue; value uniform (0 0 0); } } Code:
k PBiCG { preconditioner DILU; tolerance 1e-07; relTol 0; }; epsilon PBiCG { preconditioner DILU; tolerance 1e-07; relTol 0; }; p GAMG { tolerance 1e-7; relTol 0.01; smoother DIC; //DICGaussSeidel; //GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; }; pFinal GAMG { tolerance 1e-8; relTol 0; smoother DIC; //DICGaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; };
Kai |
different results between serial solver and parallel solver | wlt_1985 | FLUENT | 11 | October 12, 2018 08:23 |
Using a user-defined solver in OF | ozzythewise | OpenFOAM Running, Solving & CFD | 3 | February 8, 2011 15:28 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 16:49 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 16:25 |
Error during Solver | cfd guy | CFX | 4 | May 8, 2001 06:04 |
