Error compiling simpleMatrixTestC
Old   August 3, 2007, 13:05
Default Hi OpenFOAM users I tried t
jaswi is on a distinguished road
Hi OpenFOAM users
I tried to compile the simpleMatrixTest.C located in /OpenFOAM/OpenFOAM-1.4/applications/test/simpleMatrix and it gives the following error:
singh@taifun:~/OpenFOAM/OpenFOAM-1.4/applications/test/simpleMatrix> wmake
Making dependency list for source file simpleMatrixTest.C
SOURCE=simpleMatrixTest.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/singh/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc4DPOpt/simpleMatrixTest.o
simpleMatrixTest.C: In function 'int main(int, char**)':
simpleMatrixTest.C:41: error: 'class Foam::simpleMatrix<foam::vector<double> >' has no member named 'matrix'
simpleMatrixTest.C:42: error: 'class Foam::simpleMatrix<foam::vector<double> >' has no member named 'matrix'
simpleMatrixTest.C:43: error: 'class Foam::simpleMatrix<foam::vector<double> >' has no member named 'matrix'
simpleMatrixTest.C:44: error: 'class Foam::simpleMatrix<foam::vector<double> >' has no member named 'matrix'
simpleMatrixTest.C:45: error: 'class Foam::simpleMatrix<foam::vector<double> >' has no member named 'matrix'
simpleMatrixTest.C:46: error: 'class Foam::simpleMatrix<foam::vector<double> >' has no member named 'matrix'
simpleMatrixTest.C:47: error: 'class Foam::simpleMatrix<foam::vector<double> >' has no member named 'matrix'
simpleMatrixTest.C:48: error: 'class Foam::simpleMatrix<foam::vector<double> >' has no member named 'matrix'
simpleMatrixTest.C:49: error: 'class Foam::simpleMatrix<foam::vector<double> >' has no member named 'matrix'
make: *** [Make/linux64Gcc4DPOpt/simpleMatrixTest.o] Fehler 1
I tried to look in the class but it didn't help me much.
Anybody expert in C++ please take a look and help me to understand what's wrong
Thanks a lot
Kind Regards
Jaswinder
jaswi is offline   Reply With Quote
Old   September 28, 2007, 18:00
Default I got the same error messages
Frank Bos
lr103476 is on a distinguished road
I got the same error messages with the latest OF-1.4.1 versions (standard and dev). OF-1.3 worked OK.
Has anyone already fixed this problem with simpleMatrix....
Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   September 29, 2007, 05:16
Default Apparently, the matrix() funct
Frank Bos
Apparently, the matrix() function disappeared in the simpleMatrix class. The source() function is still there. I assume that simpleMatrix just works as follows
simpleMatrix<vector> A(2);
//filling the matrix
A[0][0] = 1.0;
A[0][1] = 2.0;
A[1][0] = 3.0;
A[1][1] = 4.0;
//Defining some source vector
A.source()[0] = vector(1.0, 1.0, 1.0);
A.source()[1] = vector(2.0, 2.0, 2.0);
//Solving the system
Info << A.solve() << endl;
Could someone confirm that this is the correct way?
Regards, Frank
Frank Bos
Old   September 29, 2007, 06:36
Default Yup, what you are doing is fin
Hrvoje Jasak
Yup, what you are doing is fine. Have a look at simpleMatrix.H:
template<class>
class simpleMatrix
public scalarMatrix
Therefore simpleMatrix IS-A scalarMatrix and your access functions are fine.
Enjoy,
Hrv
Hrvoje Jasak
Old   August 22, 2014, 03:32
Freedom
wenxu is on a distinguished road
Do you mean that Ax=b, where A is the simplematrix, b is the source vector and x is the solution?
wenxu is offline   Reply With Quote
Compiling error quansp OpenFOAM Installation 1 April 20, 2009 07:37
Errors when Compiling UDF: error C2040/error C2099 Julian K. FLUENT 1 December 21, 2008 00:23
compiling udf error help venkatesh4386@gmail.com FLUENT 1 November 7, 2008 02:20
Compiling ERROR hans007 FLUENT 0 December 12, 2007 04:58
compiling error baskar FLUENT 2 May 4, 2005 11:49
