Problem setting with chtmultiregionFoam
Old   May 12, 2009, 04:51
Post Problem setting with chtmultiregionFoam
Antonin
Antonin is on a distinguished road
I am using openfoam 1.5 on ubuntu (installed from ppa repo)and I'm novice in OpenFoam
To get a quick summary: I want to simulate an hot fluid flow in a steel tube.
I am trying to setup a 3D case with chtmultiregionFoam, but I'm getting some trouble with it.I am starting from the tutorial one
(see http://www.cfd-online.com/OpenFOAM_D...eater-8318.unk ).With my new case, i get a segmentation faults.
My problem is, when I run chtmultiregion this message apair:
Create time
Create fluid mesh for region gaz for time = 0.001
Create solid mesh for region Solid for time = 0.001
*** Reading fluid mesh thermophysical properties for region gaz
Adding to pdf
Adding to thermof
Selecting thermodynamics package hThermo<pureMixture<constTransport<specieThermo<hC onstThermo<perfectGas>>>>>
Adding to rhof
Adding to Kf
Adding to Uf
Adding to phif
Adding to turb
Selecting RAS turbulence model kEpsilon
Adding to DpDtf
Adding to ghf
Updating p from pd
*** Reading solid mesh thermophysical properties for region Solid
Adding to rhos
Adding to cps
Adding to Ks
Adding to Ts
Region: gaz Courant Number mean: 0 max: 0.01
Region: gaz Courant Number mean: 0 max: 0.2994012
deltaT = 0.02994012
Time = 0.0309401
Solving for fluid region gaz
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
#0 Foam::error:rintStack(Foam::Ostream&) in "/usr/lib/OpenFOAM-1.5/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/usr/lib/OpenFOAM-1.5/lib/libOpenFOAM.so"
#2 ?? in "/lib/libc.so.6"
#3 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::PatchFieldType const& Foam::fvPatch::lookupPatchField<Foam::GeometricFie ld<double, Foam::fvPatchField, Foam::volMesh>, double>(Foam::word const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const*, double const*) const in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#4 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<Foam::solidWallHeatFluxTemperatureFvPatc hScalarField>::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#5 Foam::fixedGradientFvPatchField<double>::evaluate( Foam::Pstream::commsTypes) in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#6 Foam::gradientEnthalpyFvPatchScalarField::updateCo effs() in "/usr/lib/OpenFOAM-1.5/lib/libbasicThermophysicalModels.so"
#7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::updateCoef fs() in "/usr/lib/OpenFOAM-1.5/lib/libfiniteVolume.so"
#8 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensionSet const&) in "/usr/lib/OpenFOAM-1.5/lib/libfiniteVolume.so"
#9 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacianUncorrected(Foam::GeometricFi eld<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/usr/lib/OpenFOAM-1.5/lib/libfiniteVolume.so"
#10 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/usr/lib/OpenFOAM-1.5/lib/libfiniteVolume.so"
#11 Foam::fv::laplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/usr/lib/OpenFOAM-1.5/lib/libfiniteVolume.so"
#12 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#13 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#14 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#15 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<Foam::solidWallTemperatureCoupledFvPatch ScalarField>::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#16 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<Foam::solidWallTemperatureCoupledFvPatch ScalarField>::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
#17 __libc_start_main in "/lib/libc.so.6"
#18 ?? in "/usr/lib/OpenFOAM-1.5/applications/bin/chtMultiRegionFoam"
Segmentation fault
I do not know where this error come,I think I misunderstood creatPatchDict set in the file system, but I'm not sure because I did not understand its usefulness.
For more information I have joind to my post my file system (system.tar.gz system.tar.gz).If you have any solutions please don't esitate.
Thank you.
Antonin
Antonin is offline   Reply With Quote
Old   May 16, 2009, 11:38
Aram Amouzandeh
mabinty is on a distinguished road
Antonin!
One needs to know more about your set-up (e.g. BCs). Unfortunately I was not able to download the system files.
Aram
mabinty is offline   Reply With Quote
Old   May 18, 2009, 04:09
Antonin
Aram
Thank you, for the speed of the reponce.
I joined my post my file 0 0.tar.gz , if you want more information, tell me.
I hope that this, could shed light on things.
Antonin
Old   May 18, 2009, 12:28
Antonin
chtMultiregion.tar.gz
I add this files for more comprehension
Old   April 12, 2011, 01:50
tH3f0rC3 is on a distinguished road
I want to know if it is right that a transient solver solves like this:
Create time
Create fluid mesh for region air for time = 0
Create solid mesh for region halterungsgestell for time = 0
*** Reading fluid mesh thermophysical properties for region air
Adding to thermoFluid
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
Adding to rhoFluid
Adding to KFluid
Adding to UFluid
Adding to phiFluid
Adding to gFluid
Adding to turbulence
Selecting turbulence model type RASModel
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 -0.33;
sigmak 1;
sigmaEps 1.3;
Prt 1;
Adding to radiation
Selecting radiationModel P1
Selecting absorptionEmissionModel constantAbsorptionEmission
Selecting scatterModel constantScatter
Adding to DpDtFluid
*** Reading solid mesh thermophysical properties for region halterungsgestell
Adding to rhos
Adding to cps
Adding to Ks
Adding to Ts
Region: air Courant Number mean: 0 max: 6686.693
Region: air Courant Number mean: 0 max: 0.29999969
deltaT = 4.486518e-05
Time = 4.48652e-05
Solving for fluid region air
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 4.5910077e-08, No Iterations 6
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 5.0421213e-08, No Iterations 4
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 8.4322666e-08, No Iterations 10
DICPCG: Solving for G, Initial residual = 1, Final residual = 0.090942605, No Iterations 37
DILUPBiCG: Solving for h, Initial residual = 0.99999999, Final residual = 9.7740028e-08, No Iterations 12
Min/max T:293.02624 973.15
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0021243927, No Iterations 2
time step continuity errors (air): sum local = 1.3361364e-07, global = 9.2719095e-09, cumulative = 9.2719095e-09
GAMG: Solving for p, Initial residual = 0.16696896, Final residual = 0.0001442381, No Iterations 2
time step continuity errors (air): sum local = 1.9117031e-08, global = -1.0869296e-09, cumulative = 8.1849799e-09
DILUPBiCG: Solving for epsilon, Initial residual = 0.032800783, Final residual = 9.1607404e-08, No Iterations 10
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 6.8377323e-08, No Iterations 8
Building global boundary list
Mass flux at Kettengetriebe = 0
Mass flux at Tuer = 0
Mass flux at Inlet_Outlet = 3.2890796
Mass flux at Einduesungsanlage = 0
Mass flux at Dueseneintritt = -3.0569587
Mass flux at Aussenwand = 0
Mass flux at untere_Einduesungsaustritte = 0
Mass flux at Abgasoutlet = 2.9958435e-05
Mass flux at Querverstrebungen = 0
Mass flux at Halterungsgestell = 0
Mass flux at Brenner_Einlass = 0
Net mass flux = 0.23215087
Solving for solid region halterungsgestell
DICPCG: Solving for T, Initial residual = 1, Final residual = 8.4983523e-07, No Iterations 96
DICPCG: Solving for T, Initial residual = 0.21773582, Final residual = 7.8090756e-07, No Iterations 85
Min/max T:min(T) [0 0 0 1 0 0 0] 572.93858 max(T) [0 0 0 1 0 0 0] 572.97669
ExecutionTime = 14.96 s ClockTime = 16 s
Region: air Courant Number mean: 4.6333806e-05 max: 0.29998597
deltaT = 4.4867193e-05
Time = 8.97324e-05
DILUPBiCG: Solving for Ux, Initial residual = 0.37506564, Final residual = 6.6027038e-08, No Iterations 10
DILUPBiCG: Solving for Uy, Initial residual = 0.48669134, Final residual = 4.2404301e-08, No Iterations 13
DILUPBiCG: Solving for Uz, Initial residual = 0.59158917, Final residual = 8.5674749e-08, No Iterations 12
DICPCG: Solving for G, Initial residual = 0.42589132, Final residual = 0.041371532, No Iterations 3
DILUPBiCG: Solving for h, Initial residual = 0.64209013, Final residual = 9.6251018e-08, No Iterations 13
Min/max T:561.21 973.15
GAMG: Solving for p, Initial residual = 0.45521647, Final residual = 0.00046735382, No Iterations 2
time step continuity errors (air): sum local = 9.5623605e-08, global = -9.3885069e-09, cumulative = -1.2035271e-09
GAMG: Solving for p, Initial residual = 0.060360581, Final residual = 5.0485323e-05, No Iterations 2
time step continuity errors (air): sum local = 1.4832474e-08, global = 3.1777063e-10, cumulative = -8.8575644e-10
DILUPBiCG: Solving for epsilon, Initial residual = 0.0034727837, Final residual = 3.0269126e-08, No Iterations 8
DILUPBiCG: Solving for k, Initial residual = 0.40375756, Final residual = 4.1736344e-08, No Iterations 13
Mass flux at Inlet_Outlet = 3.2784506
Mass flux at Dueseneintritt = -3.1253266
Mass flux at Abgasoutlet = 2.9972721e-05
Net mass flux = 0.15315391
DICPCG: Solving for T, Initial residual = 0.24529809, Final residual = 9.7977311e-07, No Iterations 72
DICPCG: Solving for T, Initial residual = 0.079959901, Final residual = 9.5937062e-07, No Iterations 61
Min/max T:min(T) [0 0 0 1 0 0 0] 572.92759 max(T) [0 0 0 1 0 0 0] 572.97414
ExecutionTime = 27.23 s ClockTime = 29 s
Region: air Courant Number mean: 7.9389894e-05 max: 0.30171661
deltaT = 4.4611786e-05
Time = 0.000134344
__________________________________________________ ____________________
I miss the more clear structure of the steady-state solvers like chtMultiSimpleFoam.
I have entered into controlDict as a time step 1. But the chtMultiRadFoam doesn't solve as instructed.
Does someone can explain that to me?
Many thanks!
Best regards,
tH3f0rC3
tH3f0rC3 is offline   Reply With Quote
Old   April 12, 2011, 02:35
Aram Amouzandeh
hi!
you might have set
adjustTimeStep  yes;
maxCo           0.3;
in the controclDict, i.e. the time step is controlled by a constant Courant number of 0.3. set
adjustTimeStep  no;
then the prescribed time step "deltaT" is used by the solver.
cheers,
aram
Old   April 12, 2011, 06:53
Perfect!
That was exactly the point.
Thank you!
Old   April 18, 2012, 05:36
Default chtMultiRegionFoam
namdar
Budlo is on a distinguished road
Hi
I want take a simple run from example "chtMultiRegionFoam" but when It give error. Error is " Can not read file "pints" at time 0 ".
How do you take a simple run from This solver (after blockMesh)?
Thanks
Budlo is offline   Reply With Quote
Old   April 18, 2012, 05:38
namdar
Hi
Thanks
Old   April 18, 2012, 06:42
Smile
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
Originally Posted by Budlo View Post
Hi
Thanks
Hi!
take a better look at the case files and folders at
/tutorials/heatTransfer/chtMultiRegion*
but run these cases b4 taking any conclusions. The Allrun script will do a few things. Once the case is run, take a look at the file/folder structure you got and the log files.
cht makes sense with more than 1 volume region, (solid and air,... etc) that you'll have to create using blockmesh or splitMeshregions app. Unless your case is simple it might be a little hard to set the case using OF pre-processing tools alone, but it is feasible.
gl
Best Regards
/calim
"Elune will grant us the strength"
calim_cfd is offline   Reply With Quote
Old   April 24, 2012, 09:50
namdar
Thanks a lot "Calim"
Problem setting C_MU_T with DEFINE_ADJUST Andy FLUENT 3 June 22, 2018 02:53
HELP!: swimming pool flow problem Tee FLUENT 1 September 8, 2005 08:29
Problem setting AV Marko CFX 0 March 18, 2005 08:06
Problem setting C_MU_T with DEFINE_ADJUST sarah_ron FLUENT 1 February 24, 2005 12:11
Help setting up combustor problem Tom FLUENT 0 February 5, 2005 01:20
