How to display eMesh-Files
Like Tree11Likes
  • 11 Post By wyldckat
Old   February 6, 2012, 07:34
Default How to display eMesh-Files
BT
MasterCooler is on a distinguished road
Hello OF-Community,
I am looking for a possibility to display eMesh-Files (e.g. created by surfaceFeatureExtract) in order to check their real content.
Is there any utility or the like?
Thanks in advance.
Cheers
MasterCooler
MasterCooler is offline   Reply With Quote
Old   February 6, 2012, 09:20
val46 is on a distinguished road
you can import them in paraview.
"When I meet God, I am going to ask him two questions: Why relativity? And why turbulence? I really believe he will have an answer for the first." Werner Heisenberg
val46 is offline   Reply With Quote
Old   February 6, 2012, 10:09
BT
Dear val46,
thanks for the quick reply.
I thaught that as well but I didn't work. Firstly I cannot open the eMesh file directly and even if I use the option writeVTK the generated additional file (format .extendedFeatureEdgeMesh) cannot be opened by paraView, isn't it?
I have seen that there is the option "writeObj" which also several obj files for. Amongst others there is a file "..._edgeMesh.obj" which can be opened in paraView and contains all edges. Is the content of "..._edgeMesh.obj" surely comparable with the content of the eMesh file generated in .../constant/triSurface?
Regards
Ben
Old   February 6, 2012, 11:14
ah, sorry, forgot about the obj files.
Yes, I think so.
Old   February 6, 2012, 11:24
BT
Okay, thank you.
Old   February 6, 2012, 17:10
Retired Super Moderator
Bruno Santos
Greetings to all!
You can use:
surfaceFeatureConvert constant/triSurface/file.eMesh features.obj
to convert "eMesh" to "obj". You can also use a random extension name to see which extensions are accepted.
Best regards,
Bruno
louisgag, nimasam, peppino and 8 others like this.
Old   February 8, 2012, 04:15
BT
Good morning Bruno,
I have just tested your recommendation which would completely solve my problem. Unfortunable I got the following error
|  \\    /   O peration     | Version:  2.1.x_20120105                        |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.x_20120105-eb976ba31c36
Exec   : surfaceFeatureConvert constant/triSurface/geo.eMesh geo.obj
Date   : Feb 08 2012
Time   : 09:20:51
Host   :
PID    : 24579
Case   :
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
--> FOAM FATAL IO ERROR:
Expected a '(' while reading VectorSpace<Form, Cmpt, nCmpt>, found on line 22 an error
file: constant/triSurface/geo.eMesh at line 22.
    From function Istream::readBegin(const char*)
    in file db/IOstreams/IOstreams/Istream.C at line 94.
FOAM exiting
With the same file it was possible to write out the obj files while running the surfaceExtract command. Any idea what could go wrong?
Thanks in advance for your reply.
Cheers
Ben
Old   February 8, 2012, 06:01
Bruno Santos
Hi Ben,
Open the file "constant/triSurface/geo.eMesh" with a text editor and check if there is anything out of place, as the output indicates!
Or if you can, attach the file "geo.eMesh" on your next post so we can see what might be wrong there!
Best regards,
Bruno
Old   March 14, 2017, 01:23
Default Change binary to ascii
Geon-Hong Kim
Geon-Hong is on a distinguished road
eMesh file might be written in binary format.
Change the file format from binary to ascii and try surfaceFeatureExtract and surfaceFeatureConvert again.
Geon-Hong is offline   Reply With Quote
edge file, emesh, surfacefeatureextract
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 13:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
