Help With a Cylindrical Tank Mesh
Old   February 21, 2012, 17:32
Default Help With a Cylindrical Tank Mesh
ChemE1989 is on a distinguished road
I am having difficulties with a cylindrical tank mesh. It was made by a generator that someone had posted on this site. Here is the blockMeshDict that is having problems...
| \\ / O peration | Version: 2.1.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
( 2.5 0.0 2.5) // Vertex fiveoclocksqb = 0
(-2.5 0.0 2.5) // Vertex sevenoclocksqb = 1
(-2.5 0.0 -2.5) // Vertex elevenoclocksqb = 2
( 2.5 0.0 -2.5) // Vertex oneoclocksqb = 3
( 3.5355339091057 0.0 3.53553390275978) // Vertex fiveoclockcb = 4
(-3.5355339091057 0.0 3.53553390275978) // Vertex sevenoclockcb = 5
(-3.5355339091057 0.0 -3.53553390275978) // Vertex elevenoclockcb = 6
( 3.5355339091057 0.0 -3.53553390275978) // Vertex oneoclockcb = 7
( 2.5 4 2.5) // Vertex fiveoclocksqt = 8
(-2.5 4 2.5) // Vertex sevenoclocksqt = 9
(-2.5 4 -2.5) // Vertex elevenoclocksqt = 10
( 2.5 4 -2.5) // Vertex oneoclocksqt = 11
( 3.5355339091057 4 3.53553390275978) // Vertex fiveoclockct = 12
(-3.5355339091057 4 3.53553390275978) // Vertex sevenoclockct = 13
(-3.5355339091057 4 -3.53553390275978) // Vertex elevenoclockct = 14
( 3.5355339091057 4 -3.53553390275978) // Vertex oneoclockct = 15
blocks
//square block
hex (
1 0 3 2
9 8 11 10
(10 10 10)
simpleGrading (1 1 1)
//slice1
hex (
5 4 0 1
13 12 8 9
(10 10 10)
//slice2
hex (
1 2 6 5
9 10 14 13
(10 10 10)
//slice3
hex (
2 3 7 6
10 11 15 14
(10 10 10)
//slice4
hex (
3 0 4 7
11 8 12 15
(10 10 10)
//create the quarter circles
edges
arc 4 5 (0.0 0.0 5)
arc 5 6 (-5 0.0 0.0)
arc 6 7 (0.0 0.0 -5)
arc 7 4 (5 0.0 0.0)
arc 12 13 (0.0 4 5)
arc 13 14 (-5 4 0.0)
arc 14 15 (0.0 4 -5)
arc 15 12 (5 4 0.0)
patches
patch outlet
(2 4(0 3 2 1))
(2 4(0 4 7 3))
(2 4(4 0 1 5))
(2 4(1 2 6 5))
(2 4(3 7 6 2))
patch inlet
(2 4(8 11 10 9))
(2 4(8 12 15 11))
(2 4(12 8 9 13))
(2 4(9 10 14 13))
(2 4(11 15 14 10))
wall walls
(2 4(5 4 12 13))
(2 4(5 13 14 6))
(2 4(6 14 15 7))
(2 4(7 15 12 4))
Any help as to why this is giving me errors would be greatly appreciated.
Thanks
ChemE1989 is offline   Reply With Quote
Old   February 21, 2012, 19:46
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
It is generally useful to post the error messages you get when trying to run an application, otherwise we don't know what the problem is without running it ourselves, and the possibility exists that we can't reproduce the error. Please post your error message to obtain better help.
mturcios777 is offline   Reply With Quote
Old   February 21, 2012, 20:35
Default Reply
Thank you for your reply, sorry - here is the error code.
Thank you!
XXXXXX@XXXXXXX-VirtualBox:~/OpenFOAM/XXXXX-2.1.0/run/TankBlending$ blockMesh
Build : 2.1.0-0bc225064152
Exec : blockMesh
Date : Feb 21 2012
Time : 19:19:30
Host : "xxxxxx-VirtualBox"
PID : 1681
Case : /home/xxxxx/OpenFOAM/xxxxxx-2.1.0/run/TankBlending
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Creating block mesh from
"/home/xxxxx/OpenFOAM/george-2.1.0/run/TankBlending/constant/polyMesh/blockMeshDict"
Creating curved edges
Creating topology blocks
Creating topology patches
Reading patches section
--> FOAM FATAL IO ERROR:
wrong token type - expected int, found on line 106 the punctuation token '('
file: /home/xxxxxx/OpenFOAM/george-2.1.0/run/TankBlending/constant/polyMesh/blockMeshDict:atches at line 106.
From function operator>>(Istream&, int&)
in file primitives/ints/int/intIO.C at line 68.
FOAM exiting
Old   February 22, 2012, 12:26
Marco A. Turcios
The error says that there was a '(' read when it expected a number. If you look carefully at your patches, you will see that there is an extra set of parentheses outside the patch definition along with extra numbers [i.e. (2 4(x x x x))] get rid of the extra parentheses and numbers and it should work.
Make sure you read the error messages carefully; though they can be obtuse sometimes they more often than not point you exactly where the error is, especially FOAM FATAL IO errors. They are probably the easiest to fix.
Old   February 23, 2012, 10:00
I followed your advice and got a little closer. The blockMesh command looked like it worked and a boundary file as well as several other files were created (faces, etc). However, when I use the command paraFoam to view the mesh, I get this error:
Exec : blockMesh
Date : Feb 23 2012
Time : 08:49:45
Host : "george-VirtualBox"
PID : 2155
Case : /home/george/OpenFOAM/george-2.1.0/run/TankBlending
nProcs : 1
Create time
"/home/george/OpenFOAM/george-2.1.0/run/TankBlending/constant/polyMesh/blockMeshDict"
Creating block mesh topology
Reading physicalType from existing boundary file
Default patch type set to empty
Check topology
Basic statistics
Number of internal faces : 8
Number of boundary faces : 14
Number of defined boundary faces : 14
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale 1
There are no merge patch pairs edges
Writing polyMesh
Mesh Information
boundingBox: (-5 0 -5) (5 4 5)
nPoints: 5731
nCells: 5000
nFaces: 15700
nInternalFaces: 14300
Patches
patch 0 (start: 14300 size: 500) name: outlet
patch 1 (start: 14800 size: 500) name: inlet
patch 2 (start: 15300 size: 400) name: walls
End
george@george-VirtualBox:~/OpenFOAM/george-2.1.0/run/TankBlending$ paraFoam
created temporary 'TankBlending.OpenFOAM'
"ill defined primitiveEntry starting at keyword 'patch' on line 23 and ending at line 45"
file: /home/george/OpenFOAM/george-2.1.0/run/TankBlending/0/U at line 45.
From function primitiveEntry::readEntry(const dictionary&, Istream&)
in file lnInclude/IOerror.C at line 132.
FOAM exiting
Segmentation fault
I can't seem to see what the problems are at the specified lines. Any help would be appreciated.
Thank you
Old   February 23, 2012, 12:47
Marco A. Turcios
If you read this message carefully, it tells you exactly what the problem is: something is wrong with the U file in your 0 directory, probably your BC's don't conform to the mesh.
Make sure you take the time to actually READ the error messages before you give up. It will be better for you in the long run of using Foam and you will solve your problems faster. (Its taken roughly a day for me to see this latest post and reply, whereas you probably could have solved the problem on your own in half that time).
mesh check failed, tank
[blockMesh] Mesh refinement for a cylindrical mesh lindstroem OpenFOAM Meshing & Mesh Conversion 22 June 21, 2018 01:34
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
Define mesh motion in cylindrical CS rikio CFX 0 June 3, 2009 22:21
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
