runtime is not in enumeration
Old   February 27, 2012, 07:34
Default runtime is not in enumeration
hust
kebi112358 is on a distinguished road
--> FOAM FATAL IO ERROR:
runtime is not in enumeration:
5
adjustableRunTime
clockTime
cpuTime
runTime
timeStep
Can anybody tell me how to solve this problem?
kebi112358 is offline   Reply With Quote
Old   February 27, 2012, 08:00
Retired Super Moderator
Bruno Santos
Greetings kebi112358,
5
adjustableRunTime
clockTime
cpuTime
runTime
timeStep
It's "runTime", not "runtime". OpenFOAM is case sensitive, both inside files and file names themselves!
Best regards,
Bruno
Old   February 27, 2012, 08:37
hust
Thank you so much!Problem solved!
Old   November 19, 2020, 16:56
Univerdad
DAVID1994 is on a distinguished road
adjustTablerunTime is not in enumeration:
5
adjustableRunTime
clockTime
cpuTime
runTime
timeStep
file: C:/OpenFOAM/20.09/cygwin64/opt/OpenFOAM/OpenFOAM-dev/tutorials/socavacion/
system/controlDict/writeControl at line 30.
From function Enum Foam::NamedEnum<Enum, nEnum>::read(Foam::Istream&) const
[with Enum = Foam::Time::writeControl; unsigned int nEnum = 5]
in file lnInclude/NamedEnum.C at line 69.
FOAM exiting
DAVID1994 is offline   Reply With Quote
Old   November 20, 2020, 01:57
Krapf is on a distinguished road
If you read wyldckat's post carefully, you will recognize your mistake.
Krapf is offline   Reply With Quote
surface sampling during runtime fisch OpenFOAM Post-Processing 12 February 7, 2022 07:49
runTime deji OpenFOAM 2 January 17, 2019 09:14
Microsoft Visual C++ Runtime Library Error Surgeon1983 ANSYS 1 August 18, 2013 04:11
FORTRAN runtime error, Please help Harendra Siemens 3 August 23, 2005 03:49
fortran runtime error while calculating Anna (aka new-user) Siemens 2 December 2, 2004 11:35
