March 7, 2012, 05:36 |
[Fixed] AMR and parallel run
#1 | |
Lorenzo A. Ricciardi
I'm trying to run the damBreakWithObstacle tutorial, which solves the classical dam break problem with automatic mesh refinement. No problems with the serial run. It seems also to work in parallel mode (decomposed with scotch). However, when i try to run reconstructPar, it gives Quote:
March 7, 2012, 07:49 |
#2 | |
Nima Samkhaniani
Rep Power: 24 |
first you should use "reconstructParMesh" then use "reconstructPar"
i saw the following command somewhere in forum which help me: Quote:
March 8, 2012, 03:10 |
Thanks a lot, had to do some minor changes to the code you posted but works great
March 9, 2012, 03:28 |
information regarding AMR
Suresh kumar Kannan
Hello guys,
I would like to know some basic things about the AMR in Openfoam. In which version of OF is the AMR available. And what kind of meshes can be used along with AMR. Any documentation or tutorial about the use . Thanks for your answers. bye regards K.Suresh kumar |
March 9, 2012, 03:45 |
I don't know in which version of OpenFOAM AMR first became operative, in this (2.1.0) surely it is. Maybe even in 2.0.0. For now I have just tried to follow the tutorial in tutorial/multiphase/interDymFoam/ras/damBreakWithObstacle, and works flawlessly. Given OF's capabilities to operate with generic polyhedral meshes, AMR should work with any kind of mesh. |
April 15, 2012, 06:20 |
#6 | |
Hrushikesh Khadamkar
timeList=$(ls processor0/ | awk '$1!="constant"'); for line in $timeList do echo "Recontructing mesh for t = "$line" s"; reconstructParMesh -time $line > logTmp; echo "Reconstructing fields for t = "$line" s"; reconstructPar -time $line > logTmp; echo ""; done rm logTmp; I ran the above script. It reconstructs the mesh but while reconstructing the fields it gives error. I am posting the output result of the script. Recontructing mesh for t = 0 s --> FOAM FATAL ERROR: Your time was specified as 0 but there is no polyMesh/points in that time. (there is a points file in "constant") Please rerun with the correct time specified (through the -constant, -time or -latestTime (at your option). From function reconstructParMesh in file reconstructParMesh.C at line 449. FOAM exiting Reconstructing fields for t = 0 s --> FOAM FATAL ERROR: No times selected From function reconstructPar in file reconstructPar.C at line 139. FOAM exiting Recontructing mesh for t = 0.005 s Reconstructing fields for t = 0.005 s #0 Foam::error:rintStack(Foam::Ostream&) in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so" #1 Foam::sigSegv::sigHandler(int) in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 Foam:bjectRegistry::checkOut(Foam::regIOobject&) const in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so" #4 Foam::regIOobject::~regIOobject() in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so" #5 Foam::IOList<int>::~IOList() in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libfiniteVolume.so" #6 Foam:rocessorMeshes::read() in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libreconstruct.so" #7 Foam:rocessorMeshes::readUpdate() in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libreconstruct.so" #8 main in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/bin/reconstructPar" #9 __libc_start_main in "/lib64/libc.so.6" #10 _start in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/bin/reconstructPar" ./recd: line 4: 5337 Segmentation fault (core dumped) reconstructPar -time $line >logTmp Recontructing mesh for t = 0.01 s After running the script, I have polyMesh directory in all time dumps in my case directory. But there are no fields. What can be the reason for this? Hrushikesh |
May 3, 2012, 07:23 |
Mads Reck
Actually I begin to see the same error all of a sudden. Normally the reconstructParMesh hasn't been necessary and it doesn't even help here.
Mads
Online free airfoil-mesher for OpenFOAM here |
amr, parallel error |
