pimpleDyMFoam
Old   September 19, 2012, 06:41
Default pimpleDyMFoam
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I have a problem while I am trying to use the pimpleDyMFoam solver.
As soon as I launch the simulation, I get this error:
rduser@slnxepmi05:/OPENFOAM/cases/moving_door_def_flow/test/openingNoEnergy$ pimpleDyMFoam
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.0-0bc225064152
Exec   : pimpleDyMFoam
Date   : Sep 19 2012
Time   : 12:34:52
Host   : "slnxepmi05"
PID    : 23739
Case   : /OPENFOAM/cases/moving_door_def_flow/test/openingNoEnergy
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: displacementSBRStress
Selecting motion diffusion: quadratic
Selecting motion diffusion: inverseDistance
Reading field p
Reading field U
--> FOAM FATAL IO ERROR:
Unable to set reference cell for field p
    Please supply either pRefCell or pRefPoint
file: /OPENFOAM/cases/moving_door_def_flow/test/openingNoEnergy/system/fvSolution::PIMPLE from line 69 to line 72.
    From function void Foam::setRefCell
    const volScalarField&,
    const dictionary&,
    label& scalar&,
    bool
    in file cfdTools/general/findRefCell/findRefCell.C at line 125.
FOAM exiting
What can I do?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   September 19, 2012, 09:06
fsaltara is on a distinguished road
In the fvSolution file, located in the system folder, write the options for pRefCell and pRefValue in the PIMPLE section, below the nNonOrthogonalCorrectors option:
PIMPLE
nOuterCorrectors ....
nCorrectors ......
nNonOrthogonalCorrectors ....
pRefCell 0;
pRefValue 0;
fsaltara is offline   Reply With Quote
Old   September 19, 2012, 10:11
Samuele Z
Oh, that's right.
Sorry for the question,
Samuele
Basic usage of pimpleDyMFoam jferrari OpenFOAM Pre-Processing 7 August 5, 2013 18:48
Help on segmentation fault with pimpleDyMFoam ebah6 OpenFOAM Running, Solving & CFD 2 July 5, 2013 07:27
Error with pimpleDyMFoam samiam1000 OpenFOAM 2 June 11, 2012 06:21
Running PimpleDyMFoam in parallel paul b OpenFOAM Running, Solving & CFD 8 April 20, 2011 05:21
pimpleDyMFoam stability problems cnsidero OpenFOAM Running, Solving & CFD 3 January 29, 2011 12:36
