pimpleDyMfoam simulation keeps blowing up
Like Tree15Likes
Old   April 16, 2012, 05:08
Default pimpleDyMfoam simulation keeps blowing up
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Hi all;
I'm running a pimpleDyMFoam simulation and it keeps blowing up.
Even reducing the time step down to 1e-5 does not solve the problem.
Courant Number mean: 5.46684e+95 max: 8.98336e+97
Time = 0.02416
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.02416 transformation: ((0 0 0) (0.997121 (0 0 0.075828)))
PIMPLE: iteration 1
smoothSolver:  Solving for Ux, Initial residual = 0.790411, Final residual = 0.0773137, No Iterations 13
smoothSolver:  Solving for Uy, Initial residual = 0.736195, Final residual = 0.0664809, No Iterations 15
GAMG:  Solving for p, Initial residual = 0.991861, Final residual = 0.00944463, No Iterations 3
time step continuity errors : sum local = 1.18585e+93, global = -2.66584e+77, cumulative = 1.75555e+77
PIMPLE: iteration 2
smoothSolver:  Solving for Ux, Initial residual = 0.763113, Final residual = 0.07555, No Iterations 53
smoothSolver:  Solving for Uy, Initial residual = 0.721429, Final residual = 0.0720906, No Iterations 255
GAMG:  Solving for p, Initial residual = 0.930911, Final residual = 0.00681328, No Iterations 5
time step continuity errors : sum local = 3.0917e+94, global = 8.06608e+78, cumulative = 8.24164e+78
PIMPLE: iteration 3
DILUPBiCG:  Solving for Ux, Initial residual = 0.763528, Final residual = 7.71705e-07, No Iterations 75
DILUPBiCG:  Solving for Uy, Initial residual = 0.750098, Final residual = 8.75581e-07, No Iterations 74
GAMG:  Solving for p, Initial residual = 0.982765, Final residual = 6.63145e-07, No Iterations 19
time step continuity errors : sum local = 1.39295e+91, global = -2.71812e+80, cumulative = -2.6357e+80
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2  Uninterpreted:
#3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#5  Foam::fvMatrix<double>::solve() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
#6  Foam::incompressible::RASModels::kOmegaSST::correct() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
 in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/pimpleDyMFoam"
#8  __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
My fvScehemes and fvSolutions are attached. I slightly changed them from the ones you can get from the propeller tutorial as I would like to use a k-omega model. Don't know if in doing so I messed them up…
Any help would be greatly appreciated.
lovecraft22 is offline   Reply With Quote
Old   April 16, 2012, 05:26
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
I would suggest doing the following until it stops blowing up.
Change to upwind on U.
And relax the components by 0.5.
If it stops blowing up you can then try to switch to higher order schemes and decrease the relaxation.
Tobias Adam and Muji like this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   April 16, 2012, 05:32
lore
Thank you Linnemann.
Relax the components by 0.5 means that I need this in my fvSolutions:
relaxationFactors
    "(U|k|epsilon).*"   1;
correct?
About the rest, what do you mean with change to upwind on U and switch to hig order schemes?
Thank you again for your help!
Old   April 16, 2012, 05:58
linnemann's Avatar
Niels Nielsen
yes
relaxationFactors
"(p|U|k|epsilon).*" 0.5;
in fvSolutions
and
div(phi,U) Gauss upwind;//
in fvSchemes
you are using linearUpwind which is a higher order scheme and thus inherently more unstable.
Linnemann
Old   April 16, 2012, 08:42
lore
Thank you linnemann, unfortunately had no luck with your tips…
First of all I increased the time step from 1e-5 to 1e-4 and my simulation blew up at time 0.0266.
So I changed this line I had in my fvSolution:
to this:
    "(p|U|k|omega).*"   1;
as I'm using the k-omega model and the simulation blew up again at 0.0266.
So I changed the line to this:
    "(p|U|k|omega).*"   0.5;
but again I got a blew up, this time at 0.0414, so slightly better.
So I changed these lines in my fvSchemes:
divSchemes
    default         none;
  //  div(phi,U)      Gauss upwind;
    div(phi,U)      Gauss linearUpwind grad(U);
    div(phi,k)      Gauss upwind;
    div(phi,omega) Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
to these:
divSchemes
    default         none;
//    div(phi,U)      Gauss linearUpwind grad(U);
with no result.
At this time I moved back to a time step of 1e-5 to reduce the Courant Number but the simulation blew up at 0.026…
What do you think?
Thank again.
Old   April 16, 2012, 08:58
linnemann's Avatar
Niels Nielsen
Try with transientSimpleDyMFoam
with this fvSolution file.
Linnemann
Old   April 16, 2012, 09:21
lore
Thank you. Do I need to compile it?
Old   April 16, 2012, 09:25
linnemann's Avatar
Niels Nielsen
Yes you have to
Linnemann
Old   April 16, 2012, 09:26
lore
Thank you!
I'll see what I can do!
Old   April 16, 2012, 09:50
lore
By the way, what's the difference between this and the one that comes with openFoam?
Old   April 16, 2012, 18:08
lore
Actually, my geometry is quite a simple one: just a 2D cube… How comes it cannot be solved? I mean, what can you solve with the original pimpleDyMFoam then?
Old   April 17, 2012, 01:37
linnemann's Avatar
Niels Nielsen
Hi
If it is that simple I suggest you upload it so we can have a look at your setup.
If its too big to fit here use Dropbox with a public link or a similar file sharing method.
Linnemann
Old   April 17, 2012, 04:46
lore
Thank you linnemann.
Here's my case.
Regards
Old   April 17, 2012, 12:03
Jason Eason
JulytoNovember is on a distinguished road
Excuse me Linnemann, could you please explain the differences between pimpleDyMFoam and transientSimpleDyMFoam?
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0
JulytoNovember is offline   Reply With Quote
Old   April 17, 2012, 15:26
Retired Super Moderator
Bruno Santos
Greetings to all!
In case Linnemann doesn't see the question about the differences between the two solvers, here's what I know:
  • PIMPLE is a hybrid algorithm that uses PISO and SIMPLE (I think it's PISO for outer loops and SIMPLE for inner loops). Is mostly used in OpenFOAM for transient simulations.
  • SIMPLE is an algorithm that can also do transient simulations, but not very used for this in OpenFOAM.
SIMPLE and PISO in OpenFOAM are explained here:
For more about these algorithms, you'll have to read up on CFD literature
Best regards,
Bruno
Old   April 17, 2012, 15:49
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
just a thought... you know your running an incompressible solver and your using a reference pressure of 1atm
pRefPoint (0.1 0.1 -0.005);
    pRefValue 1e5;
have you handled all the other variables to adjust to this value?
Best Regards
/calim
"Elune will grant us the strength"
calim_cfd is offline   Reply With Quote
Old   April 17, 2012, 15:58
linnemann's Avatar
Niels Nielsen
Hi lovecraft
Had a look at your case and it looks like you haven't (not to be rude) understood the setup involving rotating stuff.
If you follow the tutorial
/tutorials/incompressible/pimpleDyMFoam/mixerVesselAMI2D
I think you will get a better understanding of the whole setup involving rotating parts.
Back to your case.
I had to split it up into two meshes and then merge them back together and attach them using AMI's. You cant have a moving mesh where you only have one mesh and a zone. If you want to do it this way you should use the steady MRF approach.
Also a lot of your BC's where wrong for such a case.
Here is a nice little animation of it running.
http://dl.dropbox.com/u/15968063/output.avi
and also a link to the case that works.
http://dl.dropbox.com/u/15968063/cubo.tar.gz
And to follow up on the difference transientSimpleDyMFoam has some hard-coded stuff that makes it more stable, but it should be able to tweak pimpleDyMFoam to have a similar stability.
lovecraft22 likes this.
Linnemann
Old   April 17, 2012, 17:10
lore
Thank you a lot linnemann, that's really great! I'll have a look at the setup tomorrow. Could you also explain me what commands you ran?
Thanks again!
Old   April 17, 2012, 18:07
lore
I did some digging around and also looking at the case you uploaded I think I understood this:
1. You need to create an interface between the rotating and the stationary meshes. In my case it was a cylinder. This is the AMI (Arbitrary - btw, why "arbitrary??" - Mesh Interface);
2. You need to mesh the two regions separately, making sure you have the same cell dimensions on the AMI;
3. Merge the two meshes using mergeMesh on the running case and then run it.
I'll dig deeply on the propeller tutorial tomorrow.
What I did wrong (and I'm sorry for having posted here and on another discussion my wrong conclusions about that…) was that I only set the rotating region as a zone. This is what I usually do for the MRF and, at this point, I hope that at least is correct…
Looking forward to try an run it as I'm getting really excited about that!
Anyway thanks anybody for you help and sorry for my mistakes…
Old   April 18, 2012, 05:59
kid
cfdkid
kid is on a distinguished road
@linnemann @lore
http://dl.dropbox.com/u/70019943/roCube.tar.gz
Hello linnemann, appreciate your effort on pimpleDyFoam above.
plz find my case folder with implementation of rotating cube.
* I have only done the meshing of rotor stator inside rocube/Mesh folder.
* the next step would be to merge rotor-Mesh and stator-Mesh!!!
How to go about it?
Note: Still the case is not fully modeled, so most of the BC files are missing.
kid is offline   Reply With Quote
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
pimpleDyMFoam stability problems cnsidero OpenFOAM Running, Solving & CFD 3 January 29, 2011 12:36
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 14:29
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
