[General] Load csv data
Old   January 3, 2013, 10:16
Default Load csv data
hanonimus
alexv_cfd is on a distinguished road
Hi everyone,
I'm new to paraview. I'm trying to import some results in order to create some streams lines.
I succeded to import a csv file with all my points (x,y,z + values ), then I created a vector field with the scalar velocity x-value, y-value and z-value. I displayed correctly the magnitude of my velocity vector field.
But when i try to create the streams lines, nothing is created. I don't know why. Maybe paraview needs a mesh to create the streams lines ??
My paraview installation is fine as i can create streams lines with the paraview examples files.
Thanks for your help.
alexv_cfd is offline   Reply With Quote
Old   January 7, 2013, 15:27
Retired Super Moderator
Bruno Santos
Greetings alexv_cfd and welcome to the forum!
I Googled:
paraview csv to streamlines
And the first hit I got was this: http://www.paraview.org/pipermail/pa...ly/018201.html
The issue is that ParaView regards your data as a bunch of points in empty space. When the stream tracer looks at the empty space, it sees no field and terminates the streamline.
To see streamlines, you need a topology that interpolates field values around the points. The easiest way to do that is to apply the Delaunay 3D filter to your data (or the Delaunay 2D if your points are on a plane).
Best regards,
Bruno
Old   January 9, 2013, 11:01
Default Ok
hanonimus
It's working now. Thanks a lot.
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times vidyadhar ParaView 9 May 20, 2020 20:06
[General] How to display 3D csv data? ahgu ParaView 0 May 23, 2017 10:22
[General] export transient data to ONLY ONE csv file? macfly ParaView 7 April 6, 2016 02:43
studying a valve case mina.basta OpenFOAM 33 August 30, 2013 04:46
[OpenFOAM] exporting sample surface data in csv format sihaqqi ParaView 3 July 7, 2013 06:06
