[General] Save Animation via command line
Like Tree7Likes
  • 4 Post By wyldckat
  • 3 Post By paraJim
Old   February 23, 2013, 06:05
Smile Save Animation via command line
paraJim is on a distinguished road
Hi there,
I would like to know how to control ParaView via command line to perform the following tasks:
- Load a 3d model file (like *.stl)
- Set camera to "orbit"
- Save the animation to ogv
I simply want to create a rotating animation from a 3d model to show in a webbrowser.
If I guess correctly I have to use python to accomplish this task?
Thanks in advance
paraJim is offline   Reply With Quote
Old   February 23, 2013, 07:10
Retired Super Moderator
Bruno Santos
Greetings paraJim and welcome to the forum!
I'm short on time, so I'm only able to give the following hints:
  1. You can use pvpython or pvbatch for using/controlling from the command line. But it will not have an open ParaView window, if I remember correctly.
  2. (Semi-)Official instructions available here: http://www.paraview.org/Wiki/ParaView/Python_Scripting
  3. I don't know the level of web display you want to provide, but there is also ParaViewWeb: http://www.paraview.org/Wiki/ParaViewWeb
Good luck!
Bruno
Pagoda, paraJim, amuzeshi and 1 others like this.
Old   February 24, 2013, 12:39
Lightbulb
Hi wyldckat,
thanks for the fast response.
What I have tried so far:
I opened up ParaView, loaded a STL file and executed the following code in the python shell of ParaView:
movie = servermanager.animation.AnimationScene()
movie.ViewModules = [GetActiveView()]
movie.NumberOfFrames = 10
movie_writer = servermanager.vtkSMAnimationSceneImageWriter()
movie_writer.SetFileName("C:\movie.avi")
movie_writer.SetFrameRate(1)
movie_writer.SetQuality(2)
movie_writer.SetAnimationScene(movie.SMProxy)
movie_writer.Save()
(i found the code sample in a paraview mailing list)
Which actually creates an avi file.
What I didn't figure out is:
- How to load any 3d Model into the script?
- How to add the animation to the script? I want that the camera orbits around the object.
Here seems to be a solution for setting up the camera to orbit in python but i can't download the python script. http://www.paraview.org/pipermail/pa...ch/011400.html
I think I am getting closer.
Old   February 24, 2013, 15:05
Bruno Santos
Hi paraJim,
Sorry, I was so focused on the command line that I forgot to mention that you can use the "Python Trace" to help you generate the script that loads the files and so forth: http://www.paraview.org/Wiki/Python_GUI_Tools
Best regards,
Bruno
Old   February 24, 2013, 15:20
Smile
Hi wyldckat,
thanks for your response.
My script is almost finished. This is what I have got so far:
from paraview.simple import *
movie.NumberOfFrames = 48
# find view object
view = GetActiveView()
# Create an animation cue for the camera. This represents the "track" shown in cuethe Animation View.
cue = servermanager.animation.CameraAnimationCue()
cue.AnimatedProxy = [view]
# Add this cue to the scene.
movie.Cues = [cue]
# Now create keyframes. Let's say we are going to orbit around the object.
camera = view.GetActiveCamera()
num_of_keyframes = 10
listKeyframe = []
for i in range(0, num_of_keyframes):
    camera.Azimuth(360.0/num_of_keyframes)
    keyframe = servermanager.animation.CameraKeyFrame()
    # set the value of the key frame to the current camera location.
    keyframe.KeyTime = i*1.0/num_of_keyframes
    keyframe.Position = camera.GetPosition()
    keyframe.FocalPoint = camera.GetFocalPoint()
    keyframe.ViewUp = camera.GetViewUp()
    keyframe.ViewAngle = camera.GetViewAngle()
    listKeyframe.append(keyframe)
#cue.KeyFrames.append(keyframe) because 'append' don't exist for this object
cue.KeyFrames = listKeyframe
movie_writer.SetFrameRate(24)
movie_writer.Save()
It successfully creates the orbit animation and saves it to disk as an avi file.
One problem still exists:
- How can I load a file to the python script if I don't know the file type?
If I have a vtk file I need to run:
reader = servermanager.sources.LegacyVTKReader(FileNames='m yFile.vtk')
If I have a stl file I need to run:
reader = STLReader( FileNames=['myFile.stl'] )
Is there a "generic" reader that can read everything?
Old   February 24, 2013, 15:33
Bruno Santos
Not that I'm aware of. You'll probably have to use if statements: http://www.tutorialspoint.com/python/python_if_else.htm
Old   February 24, 2013, 15:35
Thumbs up
Hi wyldckat,
I found another way in the documentation:
Alternatively, starting with ParaView 3.8, you can use OpenDataFile() function to let ParaView pick a reader using the extension of the file.
>>> reader = OpenDataFile(“.../can.ex2”)
Thank you very much for your help.
EDIT:
Do you know how to suppress the preview dialog when running the script with pvpython.exe or pvbatch.exe?
wyldckat, deepinheart and arvindpj like this.
Old   February 24, 2013, 16:04
Bruno Santos
Originally Posted by paraJim View Post
EDIT:
I know I've tested this in the past... but it was on Linux... it's this one I think: Using offscreen rendering post #4
Not sure how it will work on Windows...
Old   February 17, 2017, 10:15
Henning86 is on a distinguished road
it is possible to load a state file and save it as animation:
servermanager.LoadState("Test.pvsm")
SetActiveView(GetRenderView())
scene = GetAnimationScene()
view.ViewSize = [1920,1080] # change resolution
#view.StereoRender = 1
#view.UseOffscreenRendering = 1
scene.EndTime = 0.1
scene.PlayMode = 'Snap To TimeSteps'
scene.AnimationTime = 2.0
# save animation images/movie
WriteAnimation('./Test.ogv', Magnification=1, FrameRate=10.0, Compression=False)
worked with paraview v52 to execute type:
pvbatch FILENAME
Henning86 is offline   Reply With Quote
animation, command line
[General] Save Animation Settings TomBot ParaView 2 August 26, 2017 07:54
[General] Save Animation using high image resolution doesn't work Omid999 ParaView 0 July 10, 2017 04:49
How to save Tecplot animation as GIF Roule Tecplot 0 January 24, 2016 06:44
How to save an animation to mpeg file jack FLUENT 1 June 25, 2008 13:26
save run animation Anis Phoenics 2 November 26, 2007 21:40
