[OpenFOAM] Problem with "R" and "uPrime2Mean"
Like Tree3Likes
  • 1 Post By samiam1000
  • 2 Post By wyldckat
Old   October 10, 2013, 10:50
Default Problem with "R" and "uPrime2Mean"
Samuele Z
samiam1000 is on a distinguished road
Dear Foamers,
I have the simpleFoam solution of a channel. I postprocessed the results calculating R (see here) but I can't `use the results'.
I mean: I can visualize them in paraFoam, but when I try to use them in the calculator, I get this error:
ERROR: In /home/zampini/OpenFOAM/ThirdParty-2.2.0/ParaView-3.12.0/VTK/Common/vtkFunctionParser.cxx, line 1480
vtkFunctionParser (0xc6ac050): Syntax error: operator expected;  see position 3
Warning: In /home/zampini/OpenFOAM/ThirdParty-2.2.0/ParaView-3.12.0/VTK/Graphics/vtkArrayCalculator.cxx, line 401
vtkPVArrayCalculator (0xc684df0): An error occured when parsing the calculator's function.  See previous errors.
Do you have an idea?
Thanks a lot,
Samuele
Ria likes this.
samiam1000 is offline   Reply With Quote
Old   October 11, 2013, 18:27
Retired Super Moderator
Bruno Santos
Greetings Samuele,
Could you please describe the steps you've taken on ParaView/paraFoam and the expression used in the calculator?
In addition, are you using point data or cell data?
Best regards,
Bruno
Old   October 12, 2013, 03:31
Samuele Z
Dear Bruno,
thanks for answering, first.
So, the steps that I do are the following:
1. I run my simulation on a channel flow and everything seems to be good (e.g. referring our results to the *famous* KMM's results).
2. I run the command "R" in OpenFOAM, in order to post-process the results.
3. I open paraFoam and I load my case.
4. I apply the calculator filter and I can manage all the variable except the R tensor.
5. If I try to use R in the calculator I get the error message posted below, both with cellData and pointData.
Thanks a lot for help.
Samuele
Old   October 12, 2013, 15:11
Bruno Santos
Hi Samuele,
It's a bug in ParaView 3.12.0. It works fine with ParaView 4.0.1.
But don't worry, with OpenFOAM you can extract the components of the symmetric tensor "R" into separate scalar fields, by running:
foamCalc components R
It will get you the component fields "0/Rxx", "0/Ryy" and so on.
Best regards,
Bruno
samiam1000 and babakflame like this.
Old   October 14, 2013, 04:03
Samuele Z
Hi Bruno and thanks for answering: I'll try this and I'll let you know if this works fine for my case. I guess yes.
Thanks a lot,
Samuele
Old   February 7, 2014, 05:58
Namsu
Usman15 is on a distinguished road
Thanks Bruno, I was facing the same problem but I have got able to fix it with your help. It worked like you said.
Usman15 is offline   Reply With Quote
UPrime2Mean calculation of Reynolds stresses MarijaB OpenFOAM Post-Processing 0 June 15, 2018 20:19
[OpenFOAM] Problem with UPrime2Mean in Paraview lcbuijs ParaView 1 August 11, 2015 05:36
Sample utility problems msrinath80 OpenFOAM Running, Solving & CFD 12 December 21, 2012 05:51
Problems sampling UPrime2Mean leonardo.morita OpenFOAM Post-Processing 5 May 10, 2012 04:36
Problem with channeloodles and foamToVTK farbfilm OpenFOAM Running, Solving & CFD 0 October 31, 2008 05:28
