[General] Paraview-Python Scripting, Accessing Data Through Objects
Like Tree4Likes
  • 4 Post By wilandlane
Old   February 7, 2014, 16:52
Default Paraview-Python Scripting, Accessing Data Through Objects
William
wilandlane is on a distinguished road
I am trying to do some post processing of simulations using Paraview through Python scripting. So far I have used Paraview's Trace function to generate the basic script but I can not seem to view/export the data:
from paraview.simple import *
tStop = 100
dt = 0.01
files = ['%s/FT_%04d.vtu' %t for t in range(int(tStop/dt))]
FT_ = XMLUnstructuredGridReader(FileName=files)
FT_.PointArrayStatus = []
FT_.CellArrayStatus = ['EP_G', 'P_G', 'P_S', 'Gas_Velocity', 'Solids_Velocity_1', 'Gas_temperature', 'Solids_temperature_1']
Calculator2 = Calculator()
Calculator2.Function = '(Gas_temperature+Solids_temperature_1)/(2)'
Calculator2.ResultArrayName = 'Tbar'
Calculator2.AttributeMode = 'Cell Data'
IntegrateVariables2 = IntegrateVariables()
PlotSelectionOverTime1 = PlotSelectionOverTime()
selection_source_3717 = IDSelectionSource( ContainingCells=0, InsideOut=0, FieldType='CELL', IDs=[-1L, 0L] )
PlotSelectionOverTime1.Selection = selection_source_3717
The new data seems to be stored in PlotSelectionOverTime1. According to Paraview, the attribute is "Row Data"; however, the class does not contain such an attribute. Is anyone familiar with Paraview's objects/attributes in Python?
Thanks!
wilandlane is offline   Reply With Quote
Old   February 16, 2014, 12:27
Retired Super Moderator
Bruno Santos
Greetings William,
I believe what you're looking for is somewhat already explained here: http://www.cfd-online.com/Forums/par...tml#post456638 post #6
Best regards,
Bruno
Old   February 19, 2014, 11:38
William
wyldckat,
You're right, that is exactly what I needed, thanks! I was actually able to get it working last week, but forgot to update my post. Here's the code I used to extract information from a "Plot Selection Over Time" filter which stores data not as Points or Cells, but as a Block.
Fetch = servermanager.Fetch(PlotSelectionOverTime1)
Block = PlotFetch.GetBlock(0)
RowData = PlotBlock.GetRowData()
Array = PlotRowData.GetArray(0)
Value = Array.GetValue(i)
wyldckat, kiddmax, Niteck and 1 others like this.
[OpenFOAM] Paraview Find Data cojua8 ParaView 2 March 19, 2018 08:57
paraview - cell data or point data on plot over line bye bye my blue OpenFOAM 0 December 13, 2016 06:07
[General] Determining number of cores and/or paraview executable via python aerogt3 ParaView 0 December 9, 2014 05:54
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
[General] paraview ignores SPACING in STRUCTURED_POINTS vtk data? jaffar ParaView 0 November 27, 2012 09:36
