[General] How to create an additional vector with {Field 4, Field 5, Field 6}
Old   August 11, 2015, 06:57
Default How to create an additional vector with {Field 4, Field 5, Field 6}
Bruno Guerrero
Bombacar is on a distinguished road
I really try to know: How to create an additional vector (different from position) with {Field 4, Field 5, Field 6}? I mean, how can I create a vector from 3 csv file's specific float columns .
In order to do that: First I read my csv file. After I applied the filter TableToPoints (with Point Data field association) and define X,Y,Z point coordinates as {Field 0, Field 1, Field 2}, and finally I tried to apply the Calculator filter
(Field 4)*iHat+(Field 5)*jHat+(Field 6)*kHat
but without success.
Bombacar is offline   Reply With Quote
Old   August 15, 2015, 18:05
Retired Super Moderator
Bruno Santos
Greetings Bombacar,
I tried this just now with ParaView 3.12, 4.1.0 and 4.3.1 and it worked just fine with all three versions. I used a CSV file with the following content:
0.0, 0.0, 0.0, 1.0, 2.0, 3.0
1.0, 0.0, 0.0, 1.0, 2.0, 3.0
2.0, 0.0, 0.0, 1.0, 2.0, 3.0
3.0, 0.0, 0.0, 1.0, 2.0, 3.0
4.0, 0.0, 0.0, 1.0, 2.0, 3.0
5.0, 0.0, 0.0, 1.0, 2.0, 3.0
Therefore I didn't have the 6th field column, but it worked fine with the columns 3, 4 and 5.
Perhaps you're not looking at the data correctly?
Where are you trying to see the resulting vectors?
Because you have the data as points only, therefore you need to apply the "Glyph" filter for having a 3D vector representation.
Best regards,
Bruno
How to create points and field files? sega OpenFOAM Post-Processing 19 July 22, 2009 03:16
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
How to create a vector field out of scalar fields anja OpenFOAM Pre-Processing 7 May 31, 2006 11:56
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
