October 28, 2016, 04:27 |
ParaView. multi-core fail
Rep Power: 11 |
I'm trying to switch on the multi-core support in my ParaView 5, but during the start it shows an error and the it simply loads in single core mode. I use OpenMPI. The error message is the following: Code:
sergey@sergey-Notebook-PC:~$ paraview AutoMPI: SUCCESS: command is: "/usr/bin/mpiexec" "-np" "2" "/usr/lib/paraview/pvserver" "--server-port=55259" AutoMPI: starting process server -------------- server output -------------- -------------------------------------------------------------------------- A requested component was not found, or was unable to be opened. This means that this component is either not installed or is unable to be used on your system (e.g., sometimes this means that shared libraries that the component requires are unable to be found/loaded). Note that Open MPI stopped checking at the first component that it did not find. Host: sergey-Notebook-PC Framework: ess Component: pmi Thanks. |
openmpi, paraview, ubuntu 14.04 lts |
[OpenFOAM] PARAVIEW aborted (core dumped) | dewey | ParaView | 1 | October 13, 2016 03:21 |
PARAVIEW aborted (core dumped) | dewey | OpenFOAM Running, Solving & CFD | 0 | October 12, 2016 12:30 |
[General] paraview after installation problem (illegal instruction core dumped) | giack | ParaView | 4 | January 21, 2014 14:18 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
General question - Fluent on multi core PC | jpo | FLUENT | 0 | March 10, 2010 13:20 |
