[OpenFOAM] OF15 for Ubuntu804 buildParaView33cvs stoped suddenly
Old   September 30, 2008, 00:31
Default OF15 for Ubuntu804 buildParaView33cvs stoped suddenly
yan
yan
yan is on a distinguished road
i compile the paraview as what the Readme said, but the compilation stopped suddenly at 37%. the putout in terminal as follow:
[ 37%] Building CXX object Utilities/VTKClientServer/Filtering/CMakeFiles/vtkFilteringCS.dir/vtkViewportCli entServer.o
[ 37%] Building CXX object Utilities/VTKClientServer/Filtering/CMakeFiles/vtkFilteringCS.dir/vtkVoxelClient Server.o
[ 37%] Building CXX object Utilities/VTKClientServer/Filtering/CMakeFiles/vtkFilteringCS.dir/vtkWedgeClient Server.o
[ 37%] Building CXX object Utilities/VTKClientServer/Filtering/CMakeFiles/vtkFilteringCS.dir/vtkFilteringCS Init.o
Linking CXX shared library ../../../bin/libvtkFilteringCS.so
[ 37%] Built target vtkFilteringCS
make: [all] error 2
i was a new learner, hope someone can tell me what's the problem? thanks in advance
yan is offline   Reply With Quote
Old   November 16, 2008, 09:55
Default Hello, I have the same prob
Axel Mohr
alexm is on a distinguished road
I have the same problem. Anyone here who solved it or has an idea?
Thanks in advance and Greetings, Axel
alexm is offline   Reply With Quote
Old   February 9, 2009, 12:58
Default try running the build utility
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
try running the build utility with the -d option to get more details on the error
-Louis
louisgag is offline   Reply With Quote
Old   June 8, 2009, 00:10
Default Possible solution ParaView and PV3FoamReader?
Christopher
hackit2me is on a distinguished road
Hello All,
I was having the exact same issue as mentioned at the top of the thread.
I am running Ubuntu 9.04
QMake 4.3.5
CMake 2.4-patch 6
gcc 4.3.1
I did some digging by going into the actual ThirdParty/ParaView3.3-cvs/platforms/linuxGcc directory and directly running the make -d command as mentioned by another poster. This revealed the system was missing some sort of X11 strings header file "StringDefs.h" The point is, by issuing apt-get install xorg-dev, ALL of the problems compiling ParaView and PV3FoamReader were immediately solved.
I am not sure if this issue is explicitly documented somewhere, that this is a required dependancy of ParaView or OpenFoam? If so, I was not able to locate it.
Should this be added to some documentation for compiling ParaView?
Chris
hackit2me is offline   Reply With Quote
Old   October 25, 2009, 19:21
Ovie Doro
ovie is on a distinguished road
I am not quite sure if this would help. But there is a thread on the compilation of paraview on this link :
http://www.cfd-online.com/Forums/ope...-script-4.html
Maybe you can take a look and see if it helps.
Thanks.
ovie is offline   Reply With Quote
