[OpenFOAM] Problem with paraFoam (ubuntu 9.04) |
August 3, 2009, 09:22 |
Pierre-Eloi Bontinck
Dear everyone,
I use binary version of OpenFOAM. I have upgraded my ubuntu from 8.10 to 9.04, and since, I have this strange behaviour. paraFoam seems to not prepare data. I have paraView opening well, with <my problem>.OpenFOAM properties selection, but no data anymore. If a export to VTK, and open with paraView, I can work as usually. I have tried with OF1.5 and OF1.6, with the same behaviour. Working from blockMesh or gmshToFoam also doesn't change anything. Do you know how I could work out to find what is my problem ? (previously it worked on Ubuntu 8.10 and OF1.5, but I cannot come back to that easily). Thank you for your help ! |
August 3, 2009, 12:14 |
I noticed also that my <problem>.OpenFOAM file created by parafoam is empty. Could be a clue ?
August 22, 2009, 00:10 |
Jon Murray
I think the <case>.OpenFOAM file is always empty. As I understand it, its just a dummy file created so that you can select a (single) file in the GUI file import utility within ParaView. The PV3FoamReader is then supposed to figure out what to do with the OpenFOAM field files in the case directory.
Regarding your problem with paraFoam not loading your case data, I had a similar issue using the original binary for paraFoam when I first installed OpenFoam (LinuxMint Elyssa 32 bit). My problem was fixed with a recompile of ParaView 3.6.1 and the PV3FoamReader module as directed by the OpenFoam installation README here: http://www.opencfd.co.uk/openfoam/doc/README.html |
August 24, 2009, 08:28 |
Thank you for your answer.
I tried this morning to compile ParaView and PV3FoamReader, but it did not change the behaviour. I've also tried to copy the compiled .so files in the plugin directory (in order for ParaView to use the correct libs), but I still did not succeed in reading my data. To my understanding, PV3FoamReader is not able to read data. When I open my case, there are wrong values in the "information" tab of the object inspector - comparing to the same case opened through VTK. Number of cells is OK, but p, U and time are not. For the moment, I still use it through VTK, and still try to find a good solution. Thank you again. |
August 24, 2009, 09:50 |
I had a suspicion about decimal point after the post. I tried to scale my mesh (in order to be > 1), and then saw something. I search with that base and found this post : http://www.cfd-online.com/Forums/openfoam-post-processing/65157-paraview-3-7-0-cvs-openfoam-reader-issues.html
I did : export LANG=C before paraFoam, and ... it finally works ! I assume there are some function, lost in a lib making reading following my language (even with a KDE config with .) and looking for , instead of . in files. By the way, having paraView compiled on my system is a good option. Some other weird behaviors of the interface are also gone. |
parafoam |
[Other] Problem in Open foam installation in ubuntu 14.04 | zannatul | OpenFOAM Installation | 2 | November 3, 2014 20:56 |
Problem installing OpenFOAM-1.6-ext on Ubuntu 14.04 | afrotimy | OpenFOAM Installation | 4 | October 4, 2014 11:36 |
ubuntu problem | fatemeh62 | OpenFOAM Installation | 0 | July 5, 2014 10:44 |
[OpenFOAM] paraFoam crashing on Ubuntu 9.10 | subash | ParaView | 1 | February 12, 2010 10:53 |
Problem running paraFoam on OpenFOAM 1.5 | sonny | OpenFOAM | 3 | June 6, 2009 20:24 |
