[OpenFOAM] paraFoam crashing on Ubuntu 9.10
Old   February 12, 2010, 02:05
Angry paraFoam crashing on Ubuntu 9.10
subash
subash is on a distinguished road
Hi
I have installed openFOAM 1.6 on a ubuntu 9.10 machine with no compilation problems.
The versions of Qt and paraFoam are 4.5.2 and 3.6.1. When the cavity problem was run, the first (blockMesh) and the second step(icoFoam) ran well without any problem. But when I tried to view the results by running paraFoam it asked to select a reader for the file, the application crashed as soon as the reader was selected throwing an exception which goes like this
Read float past end of buffer
Qt has caught an exception thrown from an event handler. Throwing
exceptions from an event handler is not supported in Qt. You must
reimplement QApplication::notify() and catch all exceptions there.
terminate called after throwing an instance of 'std::length_error'
what(): basic_string::_S_create
Aborted
Please let me know how to overcome this error.
subash is offline   Reply With Quote
Old   February 12, 2010, 10:53
suitup is on a distinguished road
Hi I had a similar problem.
This should help you, good luck
You can read some hints, there:
http://www.cfd-online.com/Forums/ope...ookbook-4.html
Or simply try:
apt-get install cmake
cd $FOAM_UTILITIES/postProcessing/graphics/PV3FoamReader
./Allwclean
./Allwmake
Or if it is not fixable:
Use foamToVTK for your OpenFoam-Files, then you can open them as vtk with paraview.
suitup is offline   Reply With Quote
[OpenFOAM.org] OpenFOAM v5 on ubuntu 14.04 - Problem with ParaFoam giorgos OpenFOAM Installation 2 October 31, 2017 07:55
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY raketenmaid ParaView 4 February 5, 2013 05:20
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
Peoblem with paraview on ubuntu 9.10 machine nabeels OpenFOAM Bugs 0 December 26, 2009 15:15
[OpenFOAM] Problem with parafoam on ubuntu 9.10 machine nabeels ParaView 0 December 25, 2009 23:12
