May 17, 2001, 15:46 |
( Bernoulli Equation )
How can we draw, in PHOTON, the lines caracterised by :
P+rVē/2=CONSTANT : ( Bernoulli Equation ) Where: P : Pressure r : density V : Velocity |
May 18, 2001, 05:46 |
Re: ( Bernoulli Equation )
Hi, GACEM
In a direct way, you can't. But, if you have a re-compilable version of PHOENICS it will be very easy in future executions. Otherwise you should read the PHI(PHIDA) file with some program and to calculate the expresion. I am assuming you had saved the density inside the PHI file if it varies inside the domain. Regards Kike |
May 24, 2001, 15:19 |
STREAM Z1 SH
this is an example for the plane Z=1 (3-D). |
coupling KE equation with navier stokes equation | prashant | FLUENT | 0 | March 7, 2008 07:05 |
Poisson equation combined with transport equation | Se-Hee | CFX | 0 | December 27, 2007 01:00 |
Has anyone tried a delta form of pressure equation pressurecorrection equation with OpenFOAM | sek | OpenFOAM Running, Solving & CFD | 2 | July 24, 2007 07:53 |
unsteady Bernoulli equation and wagner function. | Afungchui | Main CFD Forum | 0 | March 14, 2005 11:50 |
Bernoulli equation ? | Todd | Main CFD Forum | 2 | January 13, 2002 04:43 |
